Electric tongue moves but not with weight.
Friend retracted the electric tongue Jack too far in and it got stuck. I had heard warning that this would blow a fuse. It locked up, but it didn't blow the fuse. The button for the light works. Fuse looks ok, no discoloration. I manually extended it with no problem by using a tool through the top. Now the button will extend and retract the leg only when there's no weight on it/no resistance. Is there a reset button or something? Is there a pressure sensor that needs to be reset? Why would it go down, but then stop when it touches bottom? It, doesn't matter how far I need to extend or retract, it always stop when pressure/weight/resistance is applied. Likewise, using the electric button I can retract if there's no weight on it.
This is on a 2018 Rockwood mini lite.
