07-09-2020, 08:16 PM
First Time with a TT
We've done plenty of camping in the past, but usually in a cabin (and once in a tent...). But this year we took the plunge and bought used 2017 Flagstaff 21DS. It's in pretty good shape, and the original owners threw in a whole bunch of starter kit stuff and add-ons.
There were only a few broken items - the inlet for the black tank flush (they had the part in their work bin, and it was an easy fix), the dinette light didn't work, and the front exterior work light didn't work. The dinette light isn't getting power, and the work light bulb looks good - so we'll see how fixing them goes.
Our first trip beyond the driveway was to the Lincoln/Woodstock KOA (New Hampshire), about 90 minutes from home. There we discovered a few other items we needed to get, like a sewer hose extension, some pennant strings for our screen room to avoid tripping on the tie down lines, and a sunblock for the vent over the bed (since we didn't really want to get up at 0430 with the sun). All in all, though, everything went well. We'll be taking a longer trip next month. When we were cleaning up at home, we found two insulated vent inserts that work perfectly for blocking the sun!
The two customizations we're looking at are (a) making the switches for the bed lights and awning lights dimmable, and (b) modifying the end pieces on the dinette so they don't get hit when we slide into the seats.
So, there you have it - glad we found the forum!
07-09-2020, 08:23 PM
PhD, Common Sense
Some people use pool noodles for their tie-downs.
07-09-2020, 08:32 PM
Congrats on your 21DS. We had the same issue with dinette light and front exterior light. They operate on the same fuse. The wiring runs under the slide and up the slide wall. When the slide was deployed it wore the insulation off the wire and would trip the fuse. Check your fuses, chances are you have a blown 15 amp fuse which controls those lights. Replace the fuse and run the slide out and back in and see if the fuse holds. If not you have a bare wire causing the fuse to blow. Fortunately our 21DS was under warranty so I let the dealership fix it.
Enjoy you new TT.
07-10-2020, 06:09 AM
Welcome from SW Ohio , enjoy your 2017 Flagstaff 21DS TT !
2016 sunseeker 2250slec
1988 Jayco p.u.,Coleman Plantation p.u.,1989 Jayco class c, Coachman TT,1995 Little Eddie fthwheel,2007 Heartland Sundance 2500 lS fthwheel
07-10-2020, 06:14 AM
Campaholic
Welcome from Winnipeg Manitoba
 2015 F350 Platinum Powerstroke
2016 Rockwood 2650WS Ultra Lite
follow us on Instagram @
Greg.miranda.travels
07-10-2020, 06:16 AM
Georgia Rally Coordinator
Welcome to the forum. Enjoy your new to you TT and  Later RJD
2020 Shasta Phoenix SPF 27RKSS
2018 Dodge Ram 2500 6.4 3:73 gearing. Traded 2015 Chevy 2500 6.0, 4:10
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
Days camped 2020 49 days camped 2021-74 2022-18 days
07-10-2020, 07:13 AM
Welcome from Northern MN.
2020 Wolf Pack 23GOLD15
1998 Dodge Ram 3500 Cummins Diesel Dually
07-10-2020, 08:12 AM
Welcome from Wisconsin. Congrats and enjoy your 2017 Flagstaff 21DS.
2020 Flagstaff Micro Lite 22FBS
07-10-2020, 09:51 AM
Enjoy you new TT.
Sure enough, there's a spot labeled "S/O - Hitch", with a burned out fuse. Looking at the visible wires, I see no damage, so the short must be in the wall of the slide-out. Since the original owner added the slide-out cover, I suspect one of the mounting screws may have caused the problem.
But, no worries. On our maiden voyage there was plenty of light, and the hitch jack itself has a light. We'll address this after we get back from our next trip.
2017 Forest River MicroLite 21DS
2014 Toyota Sequoia
YouTube Channel
07-10-2020, 09:53 AM
And thanks for all the welcomes, everyone!
2014 Toyota Sequoia
YouTube Channel
07-10-2020, 10:28 AM
Multi-Slacker
Welcome from SoCal!'
You will enjoy that Flagstaff
Safe Travels
07-10-2020, 07:21 PM
Welcome from Michigan.......Congrats on taking the plug into camper ownership. I think you will enjoy it. So many places to explore.
