Originally Posted by dsjohns71
The toilet is plumbed from the water heater? That’s a new one on me.. is there a buddet?
As was mentioned, when the water system is drained by the low point drains AND the water heater WAS NOT put into bypass, the mix tube inside the water heater tank sets low enough that it will siphon crud from the bottom of the tank back into the plumbing where it is redistributed on repressurization.
When draining the low point drains, it is always best to bypass the water heater.
Photo is of the inlet tube in a Suburban water heater through the anode hole.
You can see how close the bottom of the tank it is positioned.
