Originally Posted by Rom
We recently purchased a 2019 2507S Rockwood. Brought it home and were running the heater to break it in. I did expect the new heater odor for awhile but it was stronger and longer lasting than our previous trailer. Out of curiosity I opened the cabinets to view the heater and lines. I found general purpose duct tape installed on all of the connections. No - not the silver HVAC foil tape. Standard grey sticky duct tape. I thought this was odd and techs at the dealership agreed they thought it was.
My dealer and I have contacted Rockwood requesting this be corrected (sent them photos). Rockwood operations representatives have informed us this is standard practice as they are using it as a screw scrim for screw retention in the ducts.
I'm still uncomfortable with it. Our previous 2019 Rockwood had no duct tape on the connections.... only the HVAC tape. My question is simply if anyone on the forum has had any issues with the duct tape there? Have enough of you seen this on your trailers so that I can believe it is truly common and not an issue?
A "screw scrim"? is that what they said? What kind of BS is that? What bodily opening did the tech. pull that phrase from? There's no such thing as screw scrim. I've been in the commercial HVAC business for 40+ years and that's wrong. The flex has a wire helix molded into the vinyl. Screws should engage that wire, then use duct tape to seal it. The foil tape is better longevity as it stands up better to the heat, especially right off the furnace but regular duct tape will last quite awhile.
New energy codes in residential and commercial construction don't allow use of tape at all, we have to seal the inner duct with liquid sealer and tape the outer vapor barrier.
I'm assuming you are referring to the peel and stick foil tape when you say "HVAC tape" correct?
