Old 07-01-2020, 09:21 PM   #1
Greetings from B.C.
Hi, all, 2nd season into our Minilite and I need advice on where the best place to place a jack is...is it the axle? frame closest to wheel/ or on the swivel arm the tire wheel floats on? Thanks for your help.
tonecrafter is offline   Reply With Quote
Old 07-01-2020, 09:29 PM   #2
It sounds like axle is a torsion axle. You should jack up on the frame as close to axle as possible, NOT on the axle tube.
Because the frame is higher and as you raise it the swing arm will drop, it would be a good idea to have some extra blocking for setting the jack on so max lift is available. Short pieces of 2 X 6 work great.
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 07-02-2020, 10:19 AM   #3
Thanks, Mike. I can see you've made many a post here. Happy travels.
Old 07-04-2020, 06:52 AM   #4
spicercars's Avatar
Welcome from Northern MN.
2020 Wolf Pack 23GOLD15
1998 Dodge Ram 3500 Cummins Diesel Dually
spicercars is offline   Reply With Quote
Old 07-04-2020, 09:44 AM   #5
geeman53's Avatar
Welcome from SW Ohio .
2016 sunseeker 2250slec
1988 Jayco p.u.,Coleman Plantation p.u.,1989 Jayco class c, Coachman TT,1995 Little Eddie fthwheel,2007 Heartland Sundance 2500 lS fthwheel
geeman53 is offline   Reply With Quote
