Old 10-29-2020, 11:44 AM   #1
Hello everyone
Can anyone tell me what kind of generator I would need to run my forest river salem villa classic 40 f den? thanks
ashleyt is offline   Reply With Quote
Old 10-29-2020, 12:40 PM   #2
bikendan's Avatar
Hi and Welcome to FRF!
Isn't your trailer a park model or destination trailer? And what do you want to run with the generator? How many air conditioners does it have? Is it located in a campground?
You need to provide a lot more information, for a clear answer.
Old 10-29-2020, 01:01 PM   #3
[QUOTE=bikendan;2442115]Hi and Welcome to FRF!
You need to provide a lot more information, for a clear answer.[/QUOTE. It is a destination model . It will be used on a piece of land with no hook ups. It has 1 ac and residential size micro and fridge .
Old 10-29-2020, 01:03 PM   #4
It is a destination model. It will ve used on a piece of land with no hookups . It has 1 ac residential fridge and micro. I am looking for some generator to power all .
Old 10-29-2020, 01:04 PM   #5
bikendan's Avatar
Then a generator with a minimum of 4000w should work. If noise is not a concern, any inexpensive open frame contractor-style generator will work. If noise IS a concern, then look for an inverter generator.
Are you expecting to run it constantly?
Old 10-29-2020, 01:20 PM   #6
NMWildcat's Avatar
It depends
If your RV is never moving and you are going to live in it, then look at something like a 7500 Generac Guardian whole home system using propane or diesel.
If you are just using it a weekend getaway, then a 4000 model would work as long as you don't run everything at once.
Scott and Liz - Southern NM
