Hello from Edmonton,Alberta, Canada!
Bought a new Flagstaff Classic Superlite fifth wheel (8528 IWKS) this spring, still working out the "bugs". Had a problem with 1. the thermostat (which is a REAL problem in Canada!) and 2. issue with CO monitor. Those seem worked out now. Another issue is 3. adding water to the water tank, it develops an "air pocket" or something and won't fill unless I press the nozzle tight against the intake.
NOW, 4, I'm trying to figure out if the TV is connected properly??? Behind the TV there is the power outlet, a cable w/booster hook up and an connector for the bedroom. The coax going to the TV comes up through a hole in the wall? Where is it coming from? Shouldn't it be connected to the booster outlet?
Oh, and 5, never seen this before but our toilet plugged twice already! I thought it was a straight pipe/drop to the black tank, apparently not! Anyone have issues?
Ken
