08-17-2021, 05:20 PM
Hi from the Gulf Coast
Hi everyone. We just picked up our first RV today, a 2004 Forest River Lexington 255ds. It seems to be a pretty solid coach, with only 38,000 miles. It’s not without some maintenance needs, but it’s definitely been well cared for over its life.
We’re looking to travel the US, with hopefully a trip to AK eventually, and possibly explore parts of Canada as well. This is all completely new to us, though we’ve been reading a bunch & watching videos for the past 1-1/2 years, to try & learn what we can about RVs & RVing. I’m sure I’ll still have questions for the experts here though!
08-17-2021, 05:23 PM
Part-Time Campground Host
Welcome from Upstate NY. Great info here. Search works great!
Craig & Cath
Days camped since 2015 (retirement): 1733
08-17-2021, 06:57 PM
Thanks! I spent some time searching around the forums here last weekend & found a bunch of answers already!
08-17-2021, 07:14 PM
Campaholic
Welcome to the forum from Winnipeg Manitoba
2015 F350 Platinum Powerstroke
2016 Rockwood 2650WS Ultra Lite
follow us on Instagram @
Greg.miranda.travels
08-17-2021, 08:46 PM
Retired Georgia Rally
Welcome to the forum from Georgia. Later RJD
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
08-17-2021, 08:58 PM
make sure the roof is secure from leaks...
especially considering your rain situation...
many have used Eternabond tape including me for preventive maintenance...
https://www.forestriverforums.com/fo...nce-90060.html
2014 Shamrock 183
08-17-2021, 09:08 PM
Originally Posted by rsdata
Oh that’s great, thanks!
08-18-2021, 07:50 AM
welcome
Start with some short trips
I would check/change oil, rear end fluid,belts,hoses,breaks, age of tires, ect Last thing you want is mechanical problems on the road
Clipper 17BH.
Chevy Avalanche 5.3
Chevy Tahoe 5.3
08-18-2021, 08:56 AM
Welcome from Wisconsin.
08-18-2021, 01:22 PM
My first question for everyone: what’s this storage compartment for? It’s just behind the generator on the driver’s side. I thought it was for the sewer hose, but it doesn’t look long enough - at least for the hose that came with the coach?
08-18-2021, 02:08 PM
Welcome from sunny Florida. As for the opening to me it would appear to be for sewer hoses. How deep and wide (diameter) is that storage area? Most sewer hoses collapse down to 50% or less than when they're fully extended size, i.e. a 10' might go down to 5' or less.
Dana & Terri - (Retired)
Our Cocker Spaniel "Shadow" (8 y/o)
Stephanie (daughter)/Rick/Callie (16 y/o)
Great Granddaughter - Cora (4 y/o)
Great Grandson - Zek (2 y/o)
Phillip (son)/Charlotte (8 y/o)
08-18-2021, 02:22 PM
I’ll have to measure it, but it’s not much(if any) deeper than 2’. The diameter is around 4” or a bit less, so it could be for a sewer hose & the one I have is either way longer than the original one or doesn’t collapse down as much.
08-18-2021, 03:18 PM
Greetings from Copperas Cove, TX!
Initially I'd have thought as others that it's for sewer hose storage but apparently not.
Is it possibly for storage of your umbilical cable/power cable?
Christian M
2021 Forest River Forester 3011DS
08-19-2021, 07:47 PM
I discovered today the coach has a connection for 120v 30a shore power(I’d just figured it was 220v), and I cam with an adaptor for a 120v 15a connection. I presume 15a wouldn’t be enough to run the rooftop air conditioner, correct?
08-19-2021, 08:08 PM
If you keep the cord short ( no long extension cords) to the house 120 VAC plug, the AC might work. Worse that can happen is you blow your house breaker, at which point just don't use the AC. Mine does work, but I have a very short run to the outlet and from the outlet to my breaker box so very little voltage drop in the wire. ALSO do NOT plug into a GFCI house outlet...
2014 Shamrock 183
08-19-2021, 08:18 PM
Ah, good news. I’ll give it a try & see what happens - thanks!
08-19-2021, 08:21 PM
IMHO you'd be pushing it. The average AC uses about 13-16 amps and that's without anything else drawing. Of course if you had a soft start, 15 A. would be enough. JMO 20 amp at the minimum without probably tripping a breaker.
