Old 06-02-2019, 08:55 AM   #1
Hot water Heater
Hi, we are new to the camping world. We have purchased a 2017 4RK Cherokee Limited and we cannot find where to turn on the bypass to the hot water tank. Cannot anyone help me,???
ID:	206172   Click image for larger version
Pelkeyam is offline   Reply With Quote
Old 06-02-2019, 09:12 AM   #2
Turn the 3-way valve in the hot (red) line (the white one with the blue line at the top and the two red lines on the left and right) so the handle is in line with the red line (probably left towards the WH, but it could go towards the right.) Also turn the 2-way valve in the cold line (blue) so the handle is in line with the blue lines.
I've attached a generic plumbing pic. See page 2. You seem to have option #2b.
2011 Traverse LT, 3.6L, FWD
Old 06-02-2019, 09:33 AM   #3
Thank you I will give it a try.
Old 06-02-2019, 09:38 AM   #4
wmtire's Avatar
I edited your pic to point to the valves rockfordroo is explaining. I have arrows pointing at the two valves.
For normal use, you want the valve on the bottom cold water line (blue line) to be open so water can enter the tank...which is usually the valve handle parallel with the line.
You also then want the bypass valve at the top, which connects the cold water blue line to the hot water red line, to be open only to the red hot water line exiting the tank.....which will require the handle on it to be parallel with the red line. (it's currently parallel with the blue crossover line, and thus bypassing the water heater tank for winterization. No hot water can exit the tank with the valve in it's current configuration, even if you have the valve on the bottom open going into the tank)
2011 Flagstaff 831 RLBSS
I'm trying to keep up with the Joneses, but every time I catch up, they refinance.
Old 06-02-2019, 09:54 AM   #5
wmtire's Avatar
This thread may help too, which we keep as a sticky at the top of the plumbing section:
http://www.forestriverforums.com/for...st-103381.html
Your tank is plumbed in just an opposite version of post #2 in the link above...but the principle works the same.
Old 06-02-2019, 11:40 AM   #6
Thank you, i found the valves and i have turned them. I then turned on the water heat , voila i waited and i now have hot water. Thank you for your help.
heater, hot water, water, water heater
