Under the library tab there is are several PDI checklists. Make sure the dealer demonstrates how ( and that ) everything works, heat,WH, AC,water system, Fridge, etc. Make sure you know what operates on 12VDC and what operates on 110VAC and where all the fuses and breakers are. Pick up some spare fuses at WalMart. Ask them to show you where and how to winterize. If you are unsure about any demonstration, video it with your phone. I recommend not signing any paperwork until it is the way you want it. "Just take it now and bring it back later on and we will fix it" means it could sit on a crowded dealer lot for some time. Do not accept it is already winterized so we can not demo water system. Re-winterizing takes them less than 20 mins and $5 worth of pink stuff. Ask for the build sheet. It is provided by FR and lists the make,model and serial # of all installed OEM equipment. Very important when you need parts or service later on.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
