I'm not familiar with your model of RV, but, if your slides and front jacks are hydraulic; can you hear the hydraulic pump running when you activate the slides? If not, you have a problem with the electrical supply to your hydraulic pump. Check all the connections, corrosion can occur at any junction and interrupt the power. Sometimes just pulling apart the connecters and reattaching them can restore a connection. And as the dealer said, check the fuses. Good Luck, God Bless.
Otegoans
Ken and Wendy
'15 silverback 29RE
'13 GMC 2500HD
Duramax/Allison
