Old 05-19-2021, 01:27 PM   #1
sCentralJoey's Avatar
Joey, Dinghy, hello!
Hi y'all! I found this forum looking for help with toad/dinghy/four-down/flat towing. I have a 27' Forester class C RV. I love it so far and I think a dinghy would make our trips even more fun. I live in the northwest USA.
sCentralJoey is offline   Reply With Quote
Old 05-20-2021, 02:45 PM   #2
Always Learning
Are you looking for toad make/model ideas? Or are you looking to see if someone is selling one.
Old 05-20-2021, 02:58 PM   #3
Both. I put up a classified ad and also posted in Towing, Tow Vehicles, Hitches & Toads
Old 05-20-2021, 03:29 PM   #4
Georgia Rally Coordinator
aceinspp's Avatar
Welcome to the forum. Easiest toad to use and hook up is a jeep. Later RJD
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
Old 05-20-2021, 03:48 PM   #5
llr
You need to figure out what class / size you want then start looking for options. If I ever go back to a MH I plan on using an F150 as a toad.
Even in certain models options can make some towable and some not. Generally most AWD and automatic transmission vehicles are not towable 4 down. Many 4WD and manual trans front wheel drive are towable 4 down.
2024 Artic Fox 3018 5th Wheel
Grand Design 2800BH TT 2021 - for sale
Prior TT 2017 Flagstaff 831CLBSS Classic Ultra lite - SOLD 5/21
TV 2024 F350 DRW - on order
Prior TV 2017 F150 6.5' bed 3.5 Eco-boost Max tow 1800lbs payload
llr is offline   Reply With Quote
Old 05-20-2021, 07:57 PM   #6
Welcome from Oklahoma!
2021 RPod 192
2010 Ford F150 4X4
Okie here!
Tinytim35 is offline   Reply With Quote
Old 05-24-2021, 01:14 PM   #7
That sounds like a great plan, thank you. I'm thinking a manual Honda Civic or Toyota Corolla would be about the right size for me and my family. Light to tow, too. I found the "2019 Good Sam Guide to Dinghy Towing" with all kinds of great info. I also connected with my local RV service shop: they said they'll help me get parts, install, and set up everything for dinghy towing.
Do you know if the auto/electric/extra braking system is a hard requirement? It seems to be in some states based on what little I've read so far.
I'm hoping to tow something less than 1.5 tons behind my RV. It seems to have plenty of power for uphill and the brakes are fine, although I've been told "the brakes in that model are already overloaded".
I'm also wondering if a transmission lube pump is necessary if the dinghy has a manual transmission, or if those lube pumps are only for automatics. This article says they're only needed for automatics, I just want to confirm with folks in here since y'all got the relevant experience and expertise.
Old 06-01-2021, 12:18 PM   #8
I found a tow-ready toad/dinghy on craigslist. Everything worked as expected during a test drive of the dinghy. We even did a test tow behind the RV (including dinghy brake lights and turn signals).
We took our first trip last weekend (~100 mi each way), and now the brake lights & turn signals stopped triggering the dinghy's brake lights and turn signals. Turning on my RV's headlights while towing turns on the dinghy rear running lights like I'd expect.
I need to get a hydraulic brake jack installed on the RV so it can actuate the existing Roadmaster brake system in the dinghy.
I'm going to take the RV and dinghy into the shop for service and to install a hydraulic brake jack. Hopefully they'll know how to make the dinghy brake lights & turn signals work while it is being towed, too. If anyone has any tips about these I'd be grateful. I'm going to check fuses now.
Old 06-07-2021, 11:02 AM   #9
Yet another lesson learned: my class C RV has hydraulic brakes and the brakemaster kit in the dinghy is an air brake. Fortunately there's a retrofit kit (98300 is for hydraulic brakes).
