Old 12-24-2022, 03:29 PM   #1
KB522
Merry Christmas & Happy Holidays!
I’ve moved up from tent camping to a 2022 Forester Classic. I plan to RV
full-time but for now staying in it part-time. I’m having some problems that I’m trying to work out. Have been fortunate to find a mobile mechanic who can do some of the work.
However, my latest problem is with my Sansui TV. This happened last night and when I called customer service this morning, the recording says they are closed until Tuesday. I turned the TV on with the remote and I cannot do anything else with it, including turning it off. It’s not the remote batteries; I put new ones in and still didn’t work. I cannot even turn tv off from the power switch on the tv.
Has anyone experienced this?
KB522 is offline   Reply With Quote
Old 12-24-2022, 03:32 PM   #2
They're all digital now.
They're all digital now. Unplug the TV's power cord for several seconds and then replug it in, so it reboots.
Larry
Larry-NC is offline   Reply With Quote
Old 12-24-2022, 03:36 PM   #3
That’s the problem. It’s not plugged into an outlet but has some wires running through the wall behind it that I cannot get to.
Old 12-24-2022, 03:42 PM   #4
12volt or 120 volt
It's either a 12-volt TV or a 120-volt TV. If you can tell (label on TV or in the manual), do the appropriate one of these procedures:
12-volt
Remove the appropriate fuse for the TV. If you can't tell which fuse it is, remove and replace each one, waiting a few seconds before replacing.
120-volt
Unplug the trailer from shore power or turn the main circuit breaker off, wait, and turn back on.
If you can't figure out which of the above procedures to do, do both.
Larry
Old 12-24-2022, 03:49 PM   #5
Thank you so much. I will try that.
Hey, we may have been neighbors at some point. I lived in Chapel Hill for 10 years.
Old 12-24-2022, 03:52 PM   #6
Raleigh...
Raleigh since 1984. Worked at IBM in RTP from 1984-2013. Retired now.
Larry
Old 12-25-2022, 11:32 AM   #7
Retired Georgia Rally
aceinspp's Avatar
Welcome to the forum and the world of RVing. Later RJD
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
Old 12-25-2022, 01:36 PM   #8
Let us know if Larry-NC's advice works to reset that tv. The fact that you can't turn off the tv by pressing the power button indicates that it needs a reset.
Welcome to the forum!
2015 Dynamax REV 24TB class C
Reverse_snowbird is online now   Reply With Quote
Old 12-25-2022, 01:51 PM   #9
If you flip the main breakers in the ac panel then go outside and turn the disconnect off. Count to ten and turn both back on should reset everything.
tomkatb is offline   Reply With Quote
Old 12-25-2022, 02:42 PM   #10
Not...
Not if it's a 12-volt TV.
Larry
Old 12-25-2022, 04:30 PM   #11
I am not familiar with this rv. Most 12 volt items run thru the fuse panel. Thus disconnecting the battery should reset.
If hillbilly wired around the disconnect most TV’s become parasitic loads.
Removing fuses one at a time works but one should use a fuse puller and be very careful.
Old 01-16-2023, 04:22 PM   #12
The OP just sent me the following private message:
We actually were able to finally reach a cable behind the tv, disconnect & reconnect. That reset it. Sorry for the delayed response. Thanks again!
Larry
