Old 04-18-2020, 11:57 AM   #1
New member and owner and first time RV owner
Hello! I am the new owner of a 2013 Wolf Pup 17RR toy hauler. Never owned an RV before...long time hiker, motocamper and car camper. I am in Chicago.
Oh, and I am trying to find out if my RV has a 30 or 50 amp system...any help? (Did I say I am new?). Asking because I do not have access to my RV right now, as it is in storage...and I can't find an answer online. I am trying to determine this so as to buy the right surge protector...
motoriousmind is offline   Reply With Quote
Old 04-18-2020, 12:02 PM   #2
wmtire's Avatar
Check your shore power cord. Does the male end have three prongs/30 amp or does it have four prongs/50 amp. This link will assist you.
http://www.myrv.us/electric/
This is what the female outlet looks like for a 50 amp outlet you plug a RV into.
And this below is what the female outlet looks like for a 30 amp outlet you plug a RV into
2011 Flagstaff 831 RLBSS
Sometimes I wonder why I'm not in an asylum. Then I take a good look around at everyone and realize...Maybe I am.
Old 04-18-2020, 12:05 PM   #3
wmtire's Avatar
This link will have links to a lot of things to get you started/educated on with an RV. It's a culmination of things that new RV owners tend to ask. Hope it helps and feel free to ask about anything you want. That's what we are here for.
https://www.forestriverforums.com/fo...ts-157524.html
BTW, welcome aboard.
Old 04-18-2020, 12:07 PM   #4
Chris Pastuzyn's Avatar
Welcome from New Jersey. You can send a picture of it as well ,so we can help.
Chris Pastuzyn is offline   Reply With Quote
Old 04-18-2020, 12:08 PM   #5
Thanks. I should have specified I am asking this because I don't have my RV with me, but it is in storage far away. And I can't find an answer online...
Old 04-18-2020, 12:08 PM   #6
Thanks! RV is in storage far away...courtesy of shelter in place order!
Old 04-18-2020, 12:13 PM   #7
Thanks for this. I will read it all.
Old 04-18-2020, 12:18 PM   #8
wmtire's Avatar
I looked up that model RV. Looking at it's size I can assure you it's of the 30 amp variety.
Old 04-18-2020, 12:25 PM   #9
I concur, I looked it up as well, took a look awhile, 30a is it
Old 04-18-2020, 12:31 PM   #10
Thank you. Is it an assumption based on the RV size? One thing I have learnt during the years is that "you don't know what you don't know". So I hope this doesn't come across as a dumb question.
Old 04-18-2020, 12:40 PM   #11
wmtire's Avatar
Yes. A 30 amp service is 120 volts X 30 amps =3600 watts. This 3600 watts is what is provided to utilize your electrical needs. This is all smaller RV need. My RV is 32 feet long and it still only has 30 amps.
A 50 amp RV uses a 120/240 volt split phase service which is 240 volts X 50 amps = 12,000 watts...... which is almost a threefold increase over a 30 amp RV. 50 amps RV's tend to be the larger ones with a lot of electrical needs, which is usually (not always) a second air conditioner (or third). Your smaller RV will not have the electrical needs to need a 50 amp service.
The links I provided previously will better explain this and I'm not going to get into the technicalities of how the 50 amp RV separates the incoming two legs of power. The links provided earlier will do this.
Old 04-18-2020, 12:58 PM   #12
wmtire's Avatar
Are you sure this RV is not a 17RP (not RR).
The reason I ask is I used a website I love which lets you go back and retrieve older internet sites. When I did this, I could get to the Wolf pup brochure for 2013 and it showed a 17RP, but not a 17RR (but that's not definitive). Let me go back a year or so and see if I can get a previous brochure.
http://www.forestriverinc.com/downlo...upbrochure.pdf
Old 04-18-2020, 01:08 PM   #13
wmtire's Avatar
OK, I went back one year and got the 2012 brochure which does indeed show the 17RR toy hauler.
Having problems with the link here. OK, had to download, then upload it.
Old 04-18-2020, 01:36 PM   #14
Retired Georgia Rally
aceinspp's Avatar
Welcome to the forum and the world of RVing. You have found out there are very knowledgeable folks here to answer your questions. Enjoy and Later RJD
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
Old 04-18-2020, 02:04 PM   #15
I confirm it is a 2013 Wolf Pup 17RR
Old 04-18-2020, 02:08 PM   #16
wmtire's Avatar
I believe you, they change the brochures and stuff like that all the time. They even have a disclaimer to that effect. That's why I went back a year to see. You will also learn that too.
Anyhow, you should have a brochure that shows the specs on your 17RR now.
You may can also look at the link for the brochure on the 17RP and compare it to your RR. They may be almost the same. If so, I saw several youtube walkthrough videos on the RP that you may can watch to help with your RR.
Old 04-18-2020, 05:37 PM   #17
Yes, I noticed that there is a lot more online about the RP model over the RR. Not sure that that is all about. I bought this puppy from a lawyer managing the estate of a deceased gentleman who had bouhgt this new and never used it due to illness. So It came with ZERO information.
Old 04-18-2020, 06:00 PM   #18
wmtire's Avatar
Glancing at the floorplans, they look similar, but the specs could be way different.
Old 04-18-2020, 06:21 PM   #19
Multi-Slacker
Welcome from SoCal! Seems WMTIRE has taken good care of you!
Safe Travels
CurtPutnam is offline   Reply With Quote
Old 04-18-2020, 07:44 PM   #20
Campaholic
Fun finders's Avatar
Welcome from Winnipeg Manitoba
2015 F350 Platinum Powerstroke
2016 Rockwood 2650WS Ultra Lite
follow us on Instagram @
Greg.miranda.travels
Fun finders is offline   Reply With Quote
first time
