Old 02-12-2021, 10:49 AM   #1
New owner of 2016 2306 MiniLite
Excited to have purchased this used unit. Should I immediately replace the tires? And it has no TV (previous owner took them out) Grill, or side table. Did it have a12 volt or standard TV? And can I get a table to hook on? Not sure I need the grill, but it would be nice to have.
Oldsguy is offline   Reply With Quote
Old 02-12-2021, 12:01 PM   #2
Welcome and congratulations on your new to you Mini Lite. WRT the tires, that depends on what shape they are in. Given that they could be original you should check closely for dry rot and wear patterns. Any concerns would cause me to change them. New tires are less expensive than the damage that could be done when tires explode at highway speeds.
I don’t know about the TV, but if you have both a 12 volt and 110 volt plug the choice is yours.
Check Amazon for “RV side mount table” and you will see some brackets, tables and grills.
2021 Rockwood Mini Lite 2205S
2011 Ford F-250 Super Duty 6.7L Diesel
WanderMore is offline   Reply With Quote
Old 02-12-2021, 12:30 PM   #3
bikendan's Avatar
Hi and Welcome to FRF.
If you want quicker answers, you should be asking your model-specific questions in the Rockwood sub-forum.
2306, lite
