Old 07-27-2020, 06:25 AM   #1
New owners of Arctic Wolf 287 BH
Hi,
We are new owners of an Arctic Wolf 287 BH. Its our first RV ever. I have so many model-spefiic questions!
We are planted on a seasonal spot for the rest of this year so we can learn, fix, and settle in.
jmorris4371 is offline   Reply With Quote
Old 07-27-2020, 06:27 AM   #2
Georgia Rally Coordinator
aceinspp's Avatar
Welcome to the forum and the world of RVing. congrats on your purchase of your new Arctic Wolf 287 BH. Enjoy and Later RJD
2020 Shasta Phoenix SPF 27RKSS
2018 Dodge Ram 2500 6.4 3:73 gearing. Traded 2015 Chevy 2500 6.0, 4:10
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
Days camped 2020 49 days camped 2021-74 2022-24 days
Old 07-27-2020, 06:47 AM   #3
geeman53's Avatar
Welcome from SW Ohio ,enjoy your Arctic Wolf 287BH TT !
2016 sunseeker 2250slec
1988 Jayco p.u.,Coleman Plantation p.u.,1989 Jayco class c, Coachman TT,1995 Little Eddie fthwheel,2007 Heartland Sundance 2500 lS fthwheel
geeman53 is offline   Reply With Quote
Old 07-29-2020, 06:57 AM   #4
spicercars's Avatar
Welcome from northern MN.
2020 Wolf Pack 23GOLD15
1998 Dodge Ram 3500 Cummins Diesel Dually
spicercars is offline   Reply With Quote
Old 08-24-2020, 02:15 PM   #5
Awesome!! We also have the 287BH. How is your airflow in the bunkroom and does your unit cool down well?
Bond_008 is offline   Reply With Quote
Old 08-24-2020, 02:41 PM   #6
The bunk room does "ok" for airflow...it stays pretty warm though. The rest of the trailer cools fairly well. Key for us is leaving doors open whenever possible.
What do you think of the 287BH? So far, with a couple of minor issues, we love it. Some of the placements are weird...like the outdoor shower not being accessible if you're plugged into 50A power.
Old 08-24-2020, 02:45 PM   #7
Yes, I agree. We had dealer add the second a/c in bedroom - non ducted. The outdoor shower makes zero sense and I think is useless given it's placement. We have scheduled to take ours back to dealer for airflow issues as the bunk room is not useable. We were really excited to upgrade to the 287BH - however, I'm really missing my Jayco we sold for many reasons, mainly, the Jayco A/C worked great for the entire coach!
Old 08-24-2020, 02:55 PM   #8
This is our first rig, so we don't have a frame of reference. I'm already trying to come up with a winterizing plan!
Old 08-24-2020, 03:27 PM   #9
We've owned 6 from pop-ups to TT - this being our first 5th wheel. I like the floor plan and overall design but the bunkroom has one vent that has virtually zero airflow and the second vent has very very little. Very very disappointed in the cooling aspect of this unit thus far.
As for winterizing, tube/pump is behind partition on driver side. Close water heater bypass so winterizing fluid doesn't go into HTH. Drain HTH. Turn valve to use pump, stick hose in winterizing bottle, pressure up system and run EVERYTHING including outdoor shower and spray port until you see pink. Pour pink stuff down pea traps and in toilet and you're good to go!!
I assume hot water tank bypass is accessible from the rear passenger side compartment?
Old 08-24-2020, 03:33 PM   #10
Great question....and NO! It is accessible by removing the bottom bunk mattress and the plywood is divided into two pieces. Ours has two screws on the half toward the back of the rv, one screw holding either side (why they didn't use a hinge I'll never know). Remove two screws and remove plywood and it sits under there - ours is a valve on hot water side and a second valve on cold water side.
Having said that, I removed partition from the adjacent storage area, used boxknife and straight edge and notched out a nice cutout so I can open storage area door and simply reach in to turn bypass valves on/off - so, in that regard, YES it is accessible if you make it accessible
Old 08-24-2020, 04:16 PM   #11
Here is my access to hot water heater from storage compartment
Name:	287BH HWH Access.jpg
Old 08-24-2020, 06:28 PM   #12
Campaholic
Fun finders's Avatar
Welcome from Winnipeg Manitoba
2015 F350 Platinum Powerstroke
2016 Rockwood 2650WS Ultra Lite
follow us on Instagram @
Greg.miranda.travels
Fun finders is offline   Reply With Quote
Old 08-25-2020, 06:03 AM   #13
Thanks, that's exactly what I meant by accessible. For the water pump, I removed the panel and affixed self-adhesive velcro so I can take that panel off/put it on multiple times without stripping the wood cleats that it screws into.
I like your idea of putting a notch in the panel for the hot water bypass. I will be stealing that idea!
Old 08-25-2020, 08:54 AM   #14
Very nice....and I'll steal your velcro idea for the panel to access the water pump valve. I don't walk around with a screwdriver/drill in my hand so easy access to these components will be nice.
Old 03-25-2021, 11:19 AM   #15
Bunk room door won't close
Hello,
We purchased an Artic Wolf 287BH new last year, its a 2020. The door to the bunk room in the back does not latch shut anymore. It seems as if the wall has shifted and is no longer straight. Has anyone else had this issue? If so will Forest River warranty the fix?
Thanks in advance!
Justin
JPTHIRY is offline   Reply With Quote
Old 03-25-2021, 12:19 PM   #16
Semperfi24's Avatar
For the access to the water heater, we cut an opening in the bottom bunk (plywood) and put an access panel in its place. Cant tell the difference if you are laying on the mattress. Fun to see the varying solutions that others have come up with for the same problems that we all encounter.
We too added the second A/C in the front bedroom. The bunk room was almost unusable because of the heat, but we went up into the vents and added the foil tape where ever we could to seal it up real good (especially at the unit in the living room). There was a lot of cold air loss at the vents, and a lot of cold air loss at the unit (because the warm air was mixing with the cold). The air was only about 4 degrees below room temp by the time it got to the vents in the bunk. After all that, we are about 16 degrees colder at the vent. The other thing we did that was very effective in keeping it cooler, was adding "mirror" tint to the windows. From the light side (outside during the day) it looks like a mirror. It cuts down on the amount of heat that enters the trailer through the large windows (especially the dining/living slide). Wasnt expensive on amazon, and fairly easy to install (having a second set of hands is highly recommended).
_________________________
2019 Ford F250 Lariat 6.7 Powerstroke
2020 Cherokee Arctic Wolf 287BH
Semperfi24 is offline   Reply With Quote
Old 03-25-2021, 12:28 PM   #17
BriaBeck's Avatar
Originally Posted by JPTHIRY View Post
Hello,
Thanks in advance!
Justin
Let's start with an easy thing first...
Is your TT all leveled out? If it is and you cannot close/open the door, something might have moved.
If it is not level, if it is sitting on uneven ground, etc.. it's possible that the TT might just be "in a twist" for lack of better explanation. It could be sitting where the whole structure is in a bind, and this is not letting the door close. Once you get it leveled out and the uneven stresses on the structure relieved, the door should operate normally. These TT's have to be somewhat "flexible" (strong enough to bend) otherwise they would break in half doing what they were made to do.
We stopped along the side of the road one time and much to my DW's horror, the entry door wouldn't open... the camper was in a bind. I pulled forward probably 100 feet, tried again, opened right up.
Brian & Becky
2018 Avenger ATI 27RBS
Champion 3500
Weber Q2000, Blackstone 22", and a whole herd of flamingoes
BriaBeck is offline   Reply With Quote
Old 04-26-2021, 02:27 PM   #18
Bottle Opener
We found a mountable bottle opener inside the ice machine. Where do you mount it?
Dkimsey is offline   Reply With Quote
Old 04-26-2021, 02:35 PM   #19
Where they able to fix the airflow?
