Originally Posted by jlbloom
There is an auxiliary jack on the Jensen and a headphones out jack on the TV. There is also a red/yellow/white output cable going from the TV to connectors on the wall directly behind the TV. Do you know what that would be for?
Thanks for your answers!
Yellow= Video Out
Red&White= audio left and right output.
If the Jensen has an aux rca input, you are good to go. Just take a standard set of rca cables and go from the tv to the Jensen. If the Jensen has an 1/8" aux input only, then you would need rca to 1/8" stereo cable. Both are very cheap cables.
