Originally Posted by Booster
How do I keep moisture from damaging my bed and walls under windows?
Do I really need to monitor the temperature inside via an app and some device if I have a pet inside the camper? I mean, yes I wouldn't leave her inside a hot car but how easily does this camper get hot inside? How would you recommend regulating the temp inside the camper? Anything I can do in order to change the temperature while I'm at work and she's inside?
Yes, so I'm looking for all kinds of ideas on how to add storage but with complete detail including size and type of screws. I need it all! All the info! haha.
Thanks for taking the time to read. Hope to see you out there!
Unless you've got a leak, moisture shouldn't be a problem while you're using it. For storage, pick up some DampRid to absorb the moisture. Just keep it away from the pet.
That camper will probably heat up like your car, so use the a/c while you're at work. There are apps to monitor the heat inside the camper, but your best bet would be a helpful neighbor to keep an eye on your pet.
Additional storage is best added using something like Command Strips. Screwing into the walls of an rv is 'iffy'.
