Old 01-12-2024, 02:12 PM   #1
RVLifeVegas's Avatar
New To RV
Good Morning Thank You for this forum. I am new to RV world. Im looking forward to learning from this forum
Currently have 2020 Sunseeker MBS
RVLifeVegas is offline   Reply With Quote
Old 01-12-2024, 02:19 PM   #2
Kanadian Kamper
kenandterry's Avatar
Welcome aboard. You might provide the full make and model of your Sunseeker rig…..there’s a few. Usually you find the model number right beside the entry door.
Read the message you got when you joined on, and it will tell you how to add this info to your signature like mine.
Ken and Terry
2018 Sunseeker 2430S-CD, nicely modified and carried by a 2017 Ford E450 Sport with 6 speed Triton V-10
kenandterry is offline   Reply With Quote
Old 01-12-2024, 03:09 PM   #3
Oaklevel's Avatar
Welcome from Virginia !!!!
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Lillie Boxer Mix (RIP)
Oaklevel is online now   Reply With Quote
Old 01-12-2024, 04:31 PM   #4
Bill and Gail's Avatar
Welcome from the Jersey Shore!
Bill and Gail is offline   Reply With Quote
Old 01-12-2024, 04:39 PM   #5
Welcome from NC.
Larry
Larry-NC is offline   Reply With Quote
Old 01-12-2024, 05:31 PM   #6
Thank You All for the warm welcome.
I hope I got the signature right
Old 01-12-2024, 05:44 PM   #7
Mr. Dan's Avatar
Your profile doesn’t show a signature. Did you click SAVE at the bottom after you did Edit Signature?
Did you click Show Signatures under ‘Visible Post Elements’ under Edit Options?
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 = 111/'19 = 86/'20 =108/'21 = 115/'22 = 135/'23 = 78/'24 = 97; Booked for 2024 = 28
Old 01-13-2024, 07:03 AM   #8
Welcome from Wisconsin.
Old 01-13-2024, 09:39 AM   #9
Welcome to the Forest River Forums!
Yes, being new to RVing can be a bit of a workout at first until you get your routine worked out for your Road Trip crew. It is different than being at a land locked home and that is part of the fun.
In this forum, you may want to click on FORUMS and pan down the list to MOTORHOMES and find the Sunseeker group here and others with you same type RV can be very helpful to you.
Welcome and enjoy the outdoor adventures.
DogMan635 is offline   Reply With Quote
Old 01-13-2024, 09:46 AM   #10
Welcome. I was new to them six months ago at the age of 70. This is a great place to learn.
Jim
East-West 34’ Alta 2850 KRL
2023 Expedition Platinum
jjscsix is offline   Reply With Quote
Old 01-13-2024, 10:06 AM   #11
Good Morning I did save it
Old 01-13-2024, 10:07 AM   #12
Hi thanks for the tip Ive been reading some of the topics on this forum and they are very helpful
Old 01-13-2024, 10:25 AM   #13
Mr. Dan's Avatar
There is no signature recorded in your profile.
Old 01-13-2024, 05:05 PM   #14
Good and I did follow your profile and did see that you saved it....Good but to have your information down at the bottom of your post. Two things you need to know. First UNDER THE MAIN MENU is User CP click and pan down to SINGNATURE, and type what you want to show, but understand there is a limit so once complete perform a PREVIEW and if you like it then go back under and click SAVE it.
Now every time you reply or make a post you will have some special information about whatever. Some members add a small photo as for me I tell you about my RV.
Enjoy and safe travels into the woods. (Here is my signature) below this:
Old 01-13-2024, 06:10 PM   #15
Thank You for the welcome. Yes i do need to find the right threads for Sunseeker MBS
Couple of things that brought me here
1. Possible leaking in my RV from not winterizing. I posted a thread under tech
2. Slide out not working
3. Rattling noise on the power entry step
I hope this forum can help me
Old 01-13-2024, 06:11 PM   #16
I see. Id have to think about what to post on the signature)
Old 01-13-2024, 06:21 PM   #17
Signature content
Why not start with name or handle, RV Year, make, and model, and your home state and region/city? As time goes by, you can modify it any time, so it doesn't deserve any more thought than that.
Larry
Old 01-13-2024, 06:24 PM   #18
Yes thats a good idea. I hope it shows this time
2019 Forest River Sunseeker 2400S MBS
Las Vegas, Nevada
Old 01-13-2024, 06:32 PM   #19
You got it!
2015 Dynamax REV 24TB class C
Reverse_snowbird is offline   Reply With Quote
Old 01-14-2024, 12:26 PM   #20
Okay, in reading your post, I hope this may help:
as for finding the THREADs for "Sunseeker" click on FOUMERS and pan down to MOTORHOMES and then the third one down is the one you need called: Forester and Sunseeker
1. the sign of leaking water is not good as you know. But check out winterizing and ask others in your new sunseeker group.
2. Slide outs, if you have more than one slide out, check under the hood for the slide out controller and in some cases, you can slip one off and fix onto the one not working to make it work and then replace them as they were, and it should work. If none of this works check with others in your group.
3. The step may just need a good inspection to see if anything is stuck in the tracks. Then before lubricating with grease, check with others in your group as all of the above.
I do one of these will be of some help to you. Let me know if you need more feedback, but first checkout your group and do a GROUP SEARCH for each and you may find that someone also had the same issue and how it was fixed. Good Luck.
