Old 05-16-2022, 06:26 PM   #1
WV Ridge Runner
New WV Owner
Hello,
Live in eastern WV and just purchased a 33.5 ft Wildwood X-lite Midwest 273QBXL TT. Spent the weekend setting/loading it up. Now planning trips and are really excited. Have a 2021 Ram 2500 CCSB Cummins and the Camco R6 Recurve WDH. Looking forward to seeing others’ setups and learning from the seasoned campers here. Take care and God Bless!
kmartin25404 is offline   Reply With Quote
Old 05-16-2022, 07:04 PM   #2
Loved camping in WV. Beautiful country!
Congratulations on your purchase and welcome to the forum!
2015 Dynamax REV 24TB class C
Reverse_snowbird is offline   Reply With Quote
Old 05-16-2022, 07:26 PM   #3
Oaklevel's Avatar
Welcome from Virginia !!!!!!
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Old 05-17-2022, 06:28 AM   #4
Georgia Rally Coordinator
aceinspp's Avatar
Welcome to the forum and congrats on your purchase of a Wildwood X-lite Midwest 273QBXL TT. Enjoy and Later RJD
2020 Shasta Phoenix SPF 27RKSS
2018 Dodge Ram 2500 6.4 3:73 gearing. Traded 2015 Chevy 2500 6.0, 4:10
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
Days camped 2020 49 days camped 2021-74 2022-18 days
Old 05-17-2022, 06:43 AM   #5
Campaholic
Fun finders's Avatar
Welcome to the forum from Winnipeg Manitoba
2015 F350 Platinum Powerstroke
2016 Rockwood 2650WS Ultra Lite
follow us on Instagram @
Greg.miranda.travels
Fun finders is offline   Reply With Quote
Old 05-17-2022, 07:04 AM   #6
Welcome from Southeastern PA. We also have the Wildwood X-Lite 273QBXL. We love it for the most part. There have been a couple of manufacturing defects, but nothing that Forest River hasn't stood behind and been willing to fix or compensate us for parts.
Before you go anywhere, I'd check the plumbing, and all the drains for leaks. That was a real lucky catch for us, and a $10 home depot trip when we de-winterized ours and were getting ready for our first shake-out trip. Otherwise we'd have been out a shower.
The people on this forum are awesome and extremely helpful about answering questions.
Congratulations, and don't forget to have fun on your adventures.
2022 Wildwood X-Lite 273QBXL
2019 Nissan Titan XD Diesel
K_M_H is offline   Reply With Quote
Old 05-17-2022, 12:26 PM   #7
Welcome from Wisconsin.
2020 Flagstaff Micro Lite 22FBS
Old 05-17-2022, 05:35 PM   #8
WV Ridge Runner
Thanks for all the replies, I planned on checking all the water lines. With the shower, did you open the small door at the bottom of the shower or are you recommending taking the panels off in the underbelly area when you found your problem? My plan is to check all the water lines I can see to ensure everything is connected. Any other checks you can think of that you did? Again, many thanks.
2022 Forest River Wildwood X-lite Midwest 273QBXL TT
2021 Ram 2500 Bighorn CCSB Cummins (Granite Metallic)
Timbrens Rear Suspension Enhancement
Old 05-17-2022, 06:39 PM   #9
I pulled the little access panel off of the bottom of the shower and that was enough to check underneath. It was very obvious that they had broken the flange under the shower pan by installing the p-trap and flange in the wrong order, then manhandling it all together. We had a pink river running from underneath the shower to the middle of the floor.
We also tested every single thing in there. Every usb port, every light, every switch, heat and AC. There was a manufacturer recall on the slide and I wrote to FR to see if it had been done. The easiest way to know is if the skirting in front of the slide is fixed to the floor. (Thanks to this forum)
Other than that, I pressure tested everything, sprayed all of the propane joints I could get to along the chassis with soapy water solution.
If I can make a suggestion, if the ladies in your family, or you, have even remotely curly or wavy hair, invest in an oxygenics fury showerhead. Mrs. H said that you could "pee harder than the stock showerhead".
The other suggestion if you haven't is to put a Maxxair or other vent cover on your bathroom so you can run the exhaust fan in the rain.
We also swapped out the stock mattress in the front for a ghostbed rv short queen. I have been told it's more comfortable than our sleep number at home.
Old 05-17-2022, 07:36 PM   #10
tuckerdog1's Avatar
Congrats & welcome. That's a nice setup. That Ram will have zero trouble towing that trailer. Do keep an eye on the payload. The 2500 Ram is a wonderful truck, but the weight of that Cummins really cuts into your payload numbers. We are always right at the limit with ours.
2016 RAM 2500 Cummins SLT Lone Star 4X4 LB
2016 Windjammer 3029W Platinum
I'm not an expert. But I play one on the internet.
You live & learn or you don't live long.
If you don't punish your children, life will.
tuckerdog1 is offline   Reply With Quote
Old 05-18-2022, 05:55 AM   #11
Thought about it this morning and realized that I should include the "Contact Us" form if I'm saying you should ask them about the recalls. This is the form that I used to get to the Midwest support: https://forestriverinc.com/rvs/conta...gionSelected=1. Tashia was fantastic and able to answer questions. I'm pretty sure she's the only person fielding all of the questions for all the Wildwood Midwest models, so please be patient and kind. Like my great-grandma used to say "You catch more flies with honey than with vinegar"
Old 05-18-2022, 11:24 PM   #12
WV Ridge Runner
Many thanks on the things to look for and check prior to use. I’m very appreciative and will look at everything you suggested.
