Old 07-16-2020, 08:39 AM   #1
Newbie from NC with a Ford F-150 Question
Greetings from Kannapolis, NC. Just bought a 2015 Wildwood X Lite. This is our first camper and we have NO clue what we are doing. We took it out for a little backing practice at a parking lot but so far, that's about it. I'm using a 2014 Ford F150 and I keep getting a "Trailer Disconnected" message every time I touch the braking. Has anyone else had this issue? Thanks.
thux45 is offline   Reply With Quote
Old 07-16-2020, 10:09 AM   #2
Mowgli64's Avatar
First suggestion is to check all the camper plugs connections for broken or corroded contacts.
2015 Wildwood X-Lite 271RBXL
2019 Ford F350 CrewCab Diesel
(2013 Ford F150 Crewcab Ecoboost traded)
Mowgli64 is offline   Reply With Quote
Old 07-16-2020, 10:30 AM   #3
SailorSam20500's Avatar
I had the same issue a while back. A good dose of contact cleaner on connection where the umbilical plugs into the truck took care of the issue. Then I got a gizmo that the umbilical sits in when not connected to keep the contacts dry and clean.
Something like one of these: https://www.walmart.com/ip/Boat-RV-C...b0383732f23206
If this doesn't do the trick, you likely have a bad connection somewhere in the brake wiring on the trailer.
Al
Save the Earth. Itís the only known planet with Beer.
When everything is coming your way, you're in the wrong lane.
S.E. Mich. Flagstaff 26FKWS / 2019 F-150 3.5 EcoBoost SCrew Propride
SailorSam20500 is offline   Reply With Quote
Old 07-16-2020, 10:30 AM   #4
Make sure your trailer wiring plug (7 pin) is plugged in all the way to your truck.
2014 Flagstaff Shamrock 21SS
2011 F-150 Crewcab ECO-BOOST Lariat 4x4
Fire Battalion Chief-09-11-2026 retirement!!!
mfeeley is offline   Reply With Quote
Old 07-16-2020, 12:36 PM   #5
bikendan's Avatar
What brake controller do you have? OEM or aftermarket BC?
I also own a 2014 F150 so it might help if you provide more information about your truck.
Like regular tow package or the Max Tow package? Trim level?
ford, newbie
