I suggest you go over to the Ford F-150 forums and get more info there on your truck’s towing capacities. 3.5EB is rated to tow 7000# with a receiver hitch with no tow package.
Engine, wheelbase, body style with bed size, type of tow package if any will be needed to cross reference your truck’s factory towing capacity. And all is limited by truck load capacity listed on the yellow door frame sticker.
Do you have a trailer brake controller? You need one at that weight in almost every state. The factory Integrated Brake Controller is fairly easy to install, lots of posts on that on the F150 forums.
Towing mirrors or mirror extensions needed depending on trailer width.
2019 Cherokee Wolf Pup 16BHS flipped axle, 5K springs, 400AH LiFePO4, 3K inverter, 400 watts CIGS solar
2019 Ford F-150 S-Crew 5.5 bed V8 w/tow package, ITBC, Tow Mirrors, 3.55, SumoSprings, 7000# GVWR, 1990#CC
Husky Centerline TS WDH 400-600# spring bars
