You have at least determined your fridge is good since it will operate from the inverter. The ac from the shore power passes thru the inverter to the fridge.
You need to check the power pedestal to ensure that it sits not trip. Is your microwave on? Check the main breaker in your breaker panel.
You are not getting shore power so check these things first..
2016 Siverback 33IK, Towed 50K+ mile2018 Ford F-350 Lariat 6.7L V8 Diesel 4WD Crew Cab
