Originally Posted by wnew813
Interesting, if you are in the United States, your power should be 120 volts probably 50 amps. If you are running 220v that will burn everything out. Campsite run 120v 30 or 50 amp. Not sure where you are getting 220v.
Actually, a 50a R/V shore connection is 240v across the 2 legs. It's wired no different than a 4 pole 240v connection to a range, welder, etc.
It is the power distribution box inside the R/V that keeps the legs separate and keeps anything from being connected at 240v.
It is the 120v 30a 3 pole R/V shore connection that electricians often get confused on and mistakenly wire it at 240v.
But alas... we never heard back from the OP as to what exactly wasn't wired correctly or what was done to rectify it.
