Vengeance 378V Toy Hauler Water Pump
Morning all,
Where is the water pump located on the 2015 Vengeance 378V Toy Hauler?
I am having an issue with the water pump on my 378V rig. It started after moving it from Richmond Virginia to Kewaunee Wisconsin. Currently i am running on the fresh water tank even though i am hooked up to shore/facility resources.
The pump is turning/cycling in short 2sec burst about every 4 minutes. I have checked all visible water connections and found no issues. I have removed panels from under the sinks and found no issues. The underbelly is enclosed (if corrugated card board constitutes enclosed). I see no wet spots on the card board nor any leakage outside.
What is causing the cycling of my pump and where is it located? Thank you for your responses.
Ray
