Use a strong light to view the the section between the door and door frame and see if the latch is actually moving when you pull on the handle. If its not moving use a thin sharp strong blade to move the latch while holding pressure against the handle to prevent the latch from moving back to the lock position I have done this before with good results. Just one idea let the forum know how you correct the problem.
Retired Navy
2016 Flagstaff 26 FKWS
