12-22-2020, 02:16 AM
07 work and play skylight install
Hello, I have a 07 work and play toy hauler and will like to install a skylight in the bathroom for more light and to kind of update it a little.y question is does anyone know where I can get the frame diagram so I can see where to cut?
Thanks in advance
12-23-2020, 09:33 AM
there is not such thing as a frame diagram that I know of. Go up on the roof in that area and look for joist or use a stud finder inside to mark the location. Myself I would add lighting before a skylight the reason is skylight are a serious source of heat in the summer and a possible source of leaks. JMHO
Retired Navy
2016 Flagstaff 26 FKWS
12-23-2020, 11:04 AM
i hate my skylights. wakes you up in morning. plastic liner inside comes loose , hot. leak potential , breaks from tree limbs,, HAIL DAMAGE.FART fans are nice , but just leave for a minute or so. Max air cover over a vent is a good investment, but they do blow off after a few years of use.
12-23-2020, 01:19 PM
I have changed the light's already, which made a significant difference. However I am also trying to get a little more head clearance in the shower that's why I thought of installing one over the shower.
12-23-2020, 01:25 PM
The light in the morning won't be a problem in the bathroom, however I also thought of falling branches and we are set up under two large trees but I was thinking of welding up a cage to go over it to deflect the falling branches/limbs.
12-24-2020, 05:21 PM
Wow! Max Air Cover Blows Off. Obviously not attached properly is my guess.
As for plastic liner, you can remove it. That is what I did over my shower.
I have had the max air cover over my bathroom vent for four years now without issue. Is it that I am lucky? Guess I need you to explain that one.
Thanks!
12-25-2020, 01:26 PM
Thanks!
X2. If a Maxx Air ever blows off, it was not installed correctly. I have had them on every RV we have owned. They also survived hail storms that destroyed every other cover/cap/skylight on the roof
The first thing I check is the headroom in the shower. You do not want your head up in the skylight some have when showering, trust me!
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
12-25-2020, 01:44 PM
I'm a super fan of Max-Air covers. I have never had one come off or loose. They are really nice when it raining. X3 what NMWildcat said I'm 5'9" so clearance is not a problem.
Retired Navy
