12-01-2017, 11:40 AM
5 Inch Fence Post Sewer Hose Storage Question
Found an area I can mount an 8 foot length of 5 inch vinyl fence post under our Lexi for the sewer hose.
Question to those of you that have used this particular mod...how did you mod the end cap to "flip up" and how did you secure the cap when closed?
I plan to have both ends being able to flip up so I can access the hose from either end. The 2 hoses I carry, the longer and an extension measure 90 inches long when collapased, so I need the 8 foot length.
Also, what did you find to be the best "cap end" to use for the "door"?
Thanks, Grumpy
Steve & Cheryl + Zoey, and Ziggy, our furry kids.
2012 Forrest River Lexington 283ts
Toad, 2013 Subaru XV Crosstrek
12-01-2017, 11:43 AM
Thanks, Grumpy
I used a elastic lanyard from sun glasses. Works great. The cap just hangs there when not on the post..
12-01-2017, 11:52 AM
I threaded a baby bungie cord through mine. Since I happened to be standing by the trailer when I read your questions, I made a couple of pics.
12-01-2017, 11:58 AM
Originally Posted by Mr. Dan
I threaded a baby bungie cord through mine. Since I happened to be standing by the trailer when I read your questions, I made a couple of pics. Attachment 157496Attachment 157497
Good idea Dan! Youroo!!
12-01-2017, 12:03 PM
Thanks Dan, good, simple idea. I've got a dozen of those mini bungee's lying around.
Thanks.
Grumpy
12-01-2017, 01:12 PM
Always Learning
I used small hinges. Though now at 4-5 years old, 2 of them have cracked from the plastic being brittle.
12-01-2017, 01:16 PM
Scoundrel
Mine just fits so tight I practically have to pry it off Lol.
2024 Geo Pro 15TB, 400W Solar, 2 Golf Cart batteries
2015 F-150 5.0L V8 XLT Crew Cab, 4x4, Tow Package, 36 gal tank, 3.55 locker, 1891 payload, Integrated Brake Controller, Roadmaster Active Suspension
Wooden Spoon Survivor
12-01-2017, 01:45 PM
Mine is attached to the gutter that slides in and out. When it's all the way in I just drop a pin through a hole in the top of the cap and thru the post cover.
12-01-2017, 01:46 PM
I put the end cap on and drilled a hole in the top, and one in the bottom and used a large gutter nail dropped in from the top as a pin.
12-01-2017, 06:23 PM
I drilled holes through sides of cap and fence post to align with each other. I secured with a 6 inch galvanized bolt and nut.
2015 Flagstaff 26VFKS
TV - 2014 F150 Crew Cab 5.0L
WDH - 1,200 Equalizer
12-01-2017, 07:03 PM
I used bungee cord also as Mr. Dan. I also put holes in the post and covered them with a soffit vent to keep the critters out and allow the slinky stench to air out. Happy RVing!
USAF Ret. ______________________________________
2015 24 FQSL NITRO TH
2015 2500 Silverado Crew Cab LTZ Duramax 4X4
2012 HD Street Glide
2008 Honda FSC600 Silver wing
12-01-2017, 07:45 PM
I used short springs at the bottom of the post. Works well...just pop out the top portion and it falls open. Disregard the bungee cord around the post...it was put there to hold the post in position while I set the permanent bolts and I just never bothered to take it out.
When open, looks like this.
BIRDS AREN’T REAL
12-01-2017, 08:24 PM
I used a brass hinge on the bottom and a snap latch on top so far no problems.
2001 Ford F-350 DRW 7.3
2011 25 RL Wildcat
former fiver 1976 Fourwinds had for 35 years
12-01-2017, 09:01 PM
I did mine the same as emm-dee, however I put the cotter pin mounting location up above the rain gutter's edge on the tube, then in the middle of the cap edge. I can then pull the cap off and set it above or below the tube since the end of my tube has nothing above it. If you use this method, I have found if you mount it in the middle, sometimes the bent part of the cotter pin will interfere with pulling the rain gutter out. It's better to have it above or below the edge of the gutter line.
12-01-2017, 11:33 PM
I did the same.
2017 Rockwood Windjammer 3006WK
12-01-2017, 11:41 PM
I also carry a 10' gutter (which I cut at 4') in the fence post. Got it and the cap latches at Lowes.
If you can find 6" pvc post I recommend that you use 6".
Paul
Big Dog House On Wheels
2013 Coachmen Freelander 28QB
on 2012 4500 Chevrolet Chassis
Paul
12-01-2017, 11:54 PM
I used eye hooks and bungee cords. You don't need to be accurate, as you do with hinges and closure hooks.
I mounted mine to the frame using stainless steel nuts and bolts and fender washers. No holes in the frame; I captured the frame with the fender washers. Moved it directly from my Roo to my Mini Lite. The pic below is after I moved it to the Mini Lite and painted it black. See the attached drawing.
2011 Traverse LT, 3.6L, FWD
12-02-2017, 05:22 AM
Thanks for all the ideas everyone. Lots of good ones.
Grumpy
