Been using the winter to make a few modifications (Pictures attached I hope): TT is a 2019 Wildwood FSX 167RB
Spice Rack and Paper Towel rack
Counter Extension and Cutting Board/Cover for Stove
Drawer under kitchen sink
Install hardwired EMS (Progressive LCHW30)
It has been fun finding ways to maximize the use of space wasted under sink
The under sink area had some wires, drain and supply pipes and the water pump. Much of that is unusable because of how the pipes and wires are routed.
Installed a drawer under the sink because the rig only had one drawer for utensils and such. The new drawer allows use of the space above the wiring and plumbing.
I wanted a hardwired EMS and there just wasn't an easy way to install it behind the breaker box so I moved it to under the sink, converted the goofy screwed in panel to a door and made it so I can see the display when I open the cabinet door.
An of course counter space is non-existent in these rigs so the extension and cover for the stove provide about a 97% increase in counter space. And the stove top will double as a back splash to protect the wall when the stove is in use.
Hope these mods might give others some ideas :-)
