Old 02-02-2013, 04:56 PM   #1
Christian Ham
A122 Interior Modification
The heavy pressedwood stock table had to go.. Put a light 3 drawer cabinet next to the wall so can have plenty of extra storage. Next purchased a Magic Folding Table that can be used inside or outside to wash dishes at the shower station. Table is called a Magic Folding Table model number 150-BG and I purchased it from Orlando RV for $32 but I see Amazon has them for $35. The table folds up to 22" by 15" and is very strong but light..I have included a picture of the screen room option that can be obtained from Forest River..Easy to put up (about 30 minutes) and uses Velcro to attach it to the camper..
ID:	23798   Click image for larger version
ID:	23799   Click image for larger version
Name:	car truck camper 020.jpg
ID:	23800   Click image for larger version
Name:	car truck camper 023.jpg
ID:	23801   Click image for larger version
Name:	car truck camper 026.jpg
n4ndr is offline   Reply With Quote
Old 02-02-2013, 05:10 PM   #2
Christian Ham
Undercoating applied next
After looking over the underside of the A122 I decided that I would further protect the bottom.. I purchased spray rubber coating from Big Lots for $3.00 a can and sprayed everything I could get at.. Noticed that he wireing was not encased so that will be my next project..Also will wire up the camper for ham radio operation. Mice and rabbits love the coating on wires..
Old 02-02-2013, 05:25 PM   #3
Christian Ham
Town and Country TV
We originally were going to pull the A122 with a Chrysler Town and Country as the van was supposedly rated to pull 3500 lbs.. Well after putting on a class 2 hitch and an electric brake system on the vehicle, we found out that we had to run the van in 3rd gear and not overdrive.. Also found out the Town and Country has had reported transmission problems pulling loads. Then found out that towing up in the Smokey Mountains where we have 7/8 degree mountain roads was a no no.. So the van went and purchased a 2012 Ford F150 XLT crew cab pickup.. Pulling the 2000 pound plus popup is no problem now.. You really have to empty out the van and keep popup weight to a minimum to protect the transmission.. There was a transmission cooler in the van but boy was the engine compartment hot..
Name:	car truck camper 032.jpg
ID:	23803   Click image for larger version
Name:	car truck camper 041.jpg
a122
