i just did this . sink drain pvc, then a reducer " if necessary" pvc pipe towards trap.nut first, then a ring gasket on pipe. there are 2 sizes of ring gaskets , prob the one with the least amount beveled edge. i purchased the parts at a mobile home supply since it is pvc to abs. most drain parts now ,and the easiest to buy ,converting to pvc is easy . i drew a pic. measure from top of drain to top of pipe. this is where reducers come in .
