Originally Posted by mmarken
if you have a 120v TV there, then you certainly have a 120v outlet that it is plugged into, making for an easy way to add another outlet to the circuit.
the couch moving out of the way will be something to deal with, but if possible, you should have a relatively easy job.
if the TV outlet is at the 'end' of a circuit run, it's even easier, as you simply can add your new wiring to it...
if the TV outlet has wires coming into, and leaving the outlet, then you have a little more involved...
but, have mercy, there's another answer, and even simpler than either of those: simply plug a short extension cord into the existing TV outlet and bring it up to behind the couch, or even 'thru' one of the cup holders. : )
