After being informed that I did not have underbelly heat(thought the small hose going to the rear bathroom was underbelly heat), I thought I might add some. Just want to keep it above freezing in extreme temps which I hope not to see too often.
I have three heat vents going to the main living area and I had already capped the one off directly below the thermostat. Still plenty of air flow to cycle on the thermostat and not duct limit.
I was able to use that four inch duct to do it. Luckily there was an opening nearby between my drawers and the duct outlet with wires running through to the underbelly. I did have to enlarge it a bit using a drill and dremel tool.
Final setup was buying some six foot bilge hose, cutting them in half and taping them all together at one end. They then fit nicely in the four inch duct. Insert them, tape it all up with aluminum foil tape and slip the other ends down through the floor.
I had originally only used one bilge hose with two sections through the opening but when I only had a high of 25 for the day my underbelly temp crept down to 28 that night. My hot water line froze below my sink. Wind was blowing pretty good too and the underbelly cover is only screwed in every so often. Maybe will put some tape the length of the seam on both sides?
The next day I added a third hose through the opening. Just capped off the end of the fourth hose. Turned the heat on and during the couple of minutes it ran to bring the cabin temp up a couple of degrees the underbelly temp went up one degree.
That night my underbelly was down to around 33 degrees with just the fireplace running. Gave it another try and after a short run of one cycle it came up a degree also. My thermometer is located closer to the rear bathroom maybe five feet away from the opening. I can feel air being pushed up through the opening for the shower drain when I remove the shower base access cover, much better with three sections of hose than just two(guess that would be 50% more volume).
The bilge hose is good for 140 degrees. Depending on where I take the temp reading on the bilge hose right at the end of the duct it is reading 140-150. Should be ok there. It only runs for a few minutes and there was no deformity on the two hoses I had already used.
Don't think I would just cut an opening if not one there already. Not without removing the underbelly cover and seeing what is in the area.
It is kind of trial and error though on getting the fireplace and propane heat to act together. The fireplace is right above all the ductwork so it warms up whenever the propane heat is on. I even block off below the fireplace but enough heat radiates up and shuts off the fireplace. Or the fireplace heat if set too high will drift up to the thermostat and not let the propane heat kick on.
Hoping trimming the panels down in height will help with keeping my water line valves from freezing. They was only maybe four inch gap at the top. Had my hot water line freeze.
