Adding Togo Wifi to 240BHXL
I purchased a Togo Roadlink for our 240BHXL and was hoping to reuse the hole in the roof used by the King prewire. Apparently this is not easily accomplished, as the King antenna on the roof is about a foot or more away from where I believe the cables for the King wifi and FM radio are routed to the entertainment center. The goal is to have the 12v wire for the Togo to come down inside the wall the TV is mounted and connect with the power from the stereo. I already have the Togo on/off switch wired and mounted in the cubie under the TV.
Outside of triple and quadruple measuring, is there a better method to drilling the hole in the roof for wiring?
