12-04-2020, 01:08 PM
Air Ride suspension on 5th Wheel
I have a 2020 Rockwood 8291 RK 5th wheel. Rear Kitchen. Stock suspension is so stiff nothing in the cabinet's stay put and the fridge bounced enough it broke the supports. I'm looking into an upgrade on suspension. Anyone with a rear kitchen have experience with Lippert Center Point, Lippert Road Armor or MORyde systems?
Bob
12-04-2020, 02:55 PM
Always Learning
When upgrading, I personally avoid anything Lippert. Too many issues and not enough testing in my not so humble opinion.
I've had friends who did the MorRyde Independent Suspension and have been very pleased with it.
Checkout my site for RVing tips, tricks, and info | Was a Fulltime Family for 5 years, now we're settlin' down for a spell
12-07-2020, 11:32 AM
To get the smoothest ride you may need to adjust the tire PSI based on the weight info from the CAT scales, tire manufacturers provide a chart that allows you to set the tire pressure based on load. Then add the Roadmaster shock absorbers system. If you travel a lot of miles the rubber sheer systems on most equalizer products dont have a good reputation for longevity.
2017 F350 Dually 6.7
2019.5 Hathaway
He who dies with the most tools, wins!
12-08-2020, 09:49 AM
Check out STI air ride by Timbren. They make complete axles with your choice of brakes in 3.5K, 5.2K, 6K, 7K, 8K and 10K.
You measure the current ride height on your stock axles, and they can supply you the air ride axles with a similar height.
They also have compressor kits for the air supply.
12-08-2020, 10:23 AM
try a different travel route if you can. you prob wont get a better resale price new suspension or not , if you decide to sell it.
12-08-2020, 01:55 PM
Always Learning
The roads just about everywhere suck.
12-08-2020, 03:00 PM
There are tons of upgrades, just depends on what you want to spend. The independent systems such as MorRyde's are great, but man, hang on to your wallet. You need to have them installed also. You could go with a shock absorber add on. (if you don't already have shocks). That would help the ride substantially. Not terribly expensive. You can get the kits through ETrailer. Tire pressure as others have mentioned will help. You need to look at the tires you're running also. Some will have stiffer sidewalls than others as well.
2003 Duramax
2017 Crusader 315
2016 Boston Whaler Montauk 150
Former Montana owner
Colorado Cruiser, Over the Pass and Down the Hill
12-08-2020, 09:47 PM
That's the problem with rear kitchens. Friends of mine had one and after on of there trips all of there knives that were in the built in holder were stuck in the walls.
12-10-2020, 12:51 PM
For the ultimate suspension upgrade: https://youtu.be/knG7L7VTeeY by MORyde
DW, DD (sometimes), DS (sometimes), 2 camping poodles
2017 Forester 3011DS
