Old 07-01-2020, 12:43 PM   #1
primo20's Avatar
Any idea what this connector is for?
So while I was cleaning and lubing my slide seals I noticed this electrical connection. It is under the main slide and seems to run to the taillights of the unit. They are zip tied off to the slide power and seem to have a wax/silicone a sealing material on them.
Any idea what they would be for?
ID:	232873   Click image for larger version
ID:	232874   Click image for larger version
primo20 is online now   Reply With Quote
Old 07-01-2020, 01:05 PM   #2
cboss's Avatar
Not sure what camper you have, but could it be for a TOAD?
Craig & Cath
2018 2902WS Rockwood Ultra Lite
2017 Ford F250 Lariat, 6.2 gas
Equalizer Hitch w/ 4-Point Sway Control
Days camped since 2016(retirement): 837
cboss is offline   Reply With Quote
Old 07-01-2020, 01:16 PM   #3
Those look like standard 12 volt waterproof connectors. They could go anywhere.
DYNAMAX 2016 FORCE HD
houstonstroker is online now   Reply With Quote
Old 07-01-2020, 01:40 PM   #4
Head Rambler
X2 ^
They're standard connectors. They could be used on brakes, lights, or almost anything 12 volt. The industry likes them because they're quick and easy to apply.
Gotta go campin!
Old 07-01-2020, 01:42 PM   #5
primo20's Avatar
@cboss it’s a 5er
@houstonstroker thanks. Didn’t want to pull the end off to see if it was constant 12v. But thought it would be good for under mount lighting.
I also don’t have an awning on that slide. Thought possibly it was awning power as it was an option.
2018 DURANGO 2500 343MBQ | 2019 Silverado 3500 DRW Duramax
Old 07-01-2020, 01:43 PM   #6
primo20's Avatar
Thanks bama rambler
Old 07-01-2020, 02:01 PM   #7
Just as confused as you
Scrapper's Avatar
No, don't pull on them as that could cause the wires inside to loose connection. If that happens the only way to fix it would be to cut them off and replace.
Richard & Jill
Camping since 1989, seasonal since 2000
The Faster I Go, The Behinder I Get.
Scrapper is online now   Reply With Quote
Old 07-01-2020, 02:27 PM   #8
primo20's Avatar
Thanks. I meant the cap. Iím sure it comes off?
Old 07-01-2020, 08:41 PM   #9
Scrapper's Avatar
Originally Posted by primo20 View Post
Thanks. I meant the cap. I’m sure it comes off?
No, that is not a cap. It is made so you push the unstripped wires into it then squeeze with a tool or pliers. Inside there is a piece of metal with slots that cut through the insulation to make contact with the wires. Once it is crimped the cap is pretty much flush with the body. Look close to the first pic you will see the metal tangs gripping the wires.
Name:	3M Scotchlok UR2 butt connector.jpg
Richard & Jill
Old 07-02-2020, 08:25 AM   #10
primo20's Avatar
Excellent thank you. Good to know! Much appreciated
Old 07-02-2020, 06:59 PM   #11
Only bad thing is on a 2104 FR Surveyor SV34RLTS they were not water proof cost me $700.00 to diagnose and repair “no trailer brakes”. Those connectors were at the real axles
And connected the wires for the brakes to the wires from the frame. Actually had sand and moisture in them. Unfortunately for me the RV repair specialist checked them last!!
2014 Forest River Surveyor Pilot
2019 F150 4x4 screw Lariat
lorenc is offline   Reply With Quote
Old 07-03-2020, 12:29 AM   #12
Nice pics of the butt connectors
Scrapper is exactly right about how you use them. Just to add to that (hope you don't mind) the yellow cap is a 3M Scotchlok UY2 Butt Connector for 2 wires and the red cap is a Scotchlok UR Butt Connector for 3 wires and both are gel filled to keep out moisture. The only problem with these is that they are made for 19 to 26 light gauge wires and more specifically telephone cables. If I'm missing something here I'm all ears.
If you know of any similar type connectors for 12, 14, or 16 gauge typical 12v cables like they use on travel trailers I would sure like to know how to get them if anyone knows. Thanks.
Pred is offline   Reply With Quote
Old 07-03-2020, 07:12 AM   #13
Pretty funny, this one has a disclaimer that it is for professional use only.
https://www.amazon.com/3M-Scotchlok-...xpY2s9dHJ1ZQ==
Here is a different brand, same idea
https://www.amazon.com/Wire-Connecto...hi&sr=1-7&th=1
2020 Coachmen Mirada Select 37RB
2019 Ford Mustang
H&H Aluminum Car Hauler
Cricket RX5 Golf(?) cart
DougW is online now   Reply With Quote
Old 07-03-2020, 07:22 AM   #14
dbledan's Avatar
Man they are proud of those!
I use these. Water proof and reusable. Simple to install and work great. I use them on the truck and trailer.
Be sure to match the wire gauge to get the water tight seal.
https://www.amazon.com/dp/B00CHQ0F1E..._mjBNz5K6MBV8J
If you want to Tap a wire get these.
https://www.amazon.com/dp/B004D0C2RC..._JaruSN7o32sJA
dbledan is offline   Reply With Quote
Old 07-03-2020, 07:24 AM   #15
Usually Confused Member
emm-dee's Avatar
Not waterproof but itís easy to waterproof them. 12-24 awg.
https://www.amazon.com/Wago-Lever-Nu...dDbGljaz10cnVl
2018 Forester 3051S (aka Clyde)
2015 Wrangler Toad (aka Bonnie)
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
emm-dee is online now   Reply With Quote
Old 07-03-2020, 09:16 AM   #16
Good to know.
Ditto primo20 - Thanks on the various connector info from DougW, dbledan, and emm-dee.
Old 07-03-2020, 03:11 PM   #17
Tip10's Avatar
Once you connect em ó DIP EM
https://www.lowes.com/pd/Flex-Seal-L...E&gclsrc=aw.ds
If I am Lost itís because I want to be Lost.
Tip10 is online now   Reply With Quote
Old 07-03-2020, 06:31 PM   #18
emm-dee's Avatar
Originally Posted by Tip10 View Post
Sorry, but I wouldnít use any of the FlexSeal junk on anything. The few wagos I needed to waterproof (awning pole lights) had a thick coat of Lexel applied. Guaranteed waterproof and lasts probably longer than the RV will.
Old 07-03-2020, 10:10 PM   #19
Scrapper's Avatar
I dip them in liquid electrical tape, it's been around a lot longer and doesn't turn brittle and flake off like that Flex Seal crap.
Richard & Jill
Old 07-10-2020, 08:09 AM   #20
It looks like a 12 volt connector used to join two low voltage electrical lines.
MisterVick is offline   Reply With Quote
