11-15-2022, 04:02 PM
Anyone replace this exterior light- seeking options
The exterior light on the front of my Mini Lite 2508 no longer works. The light actucally only worked for a few months after it was new, and as time progressed the function and reliability of the light diminished.
The light that no longer works has an on/off switch
I am looking for options for a good replacement that also offers an on/off switch.
I can replace with the same light, but am hesitant because of how short lived the light lasted that no longer works.
Any feedback would be helpful.
Pic attached of the light I want to replace
11-15-2022, 04:20 PM
many options, this one looks like some i've seen recently. Check out eTrailer, they have a decent selection of lights.
2021 Coachmen Spirit 1943RB
2013 GMC Yukon
11-15-2022, 04:24 PM
Kanadian Kamper
From what I can see from your photo, it looks like this light, and whatever replacement you get, is facing forward. This subjects the light to the maximum grit and water of any exterior light. I would make sure to seal it with as much silicone as possible to help it in the future.
Just saying.
Ken and Terry
11-15-2022, 05:49 PM
I have the same light on my rig. It is an OPTRONICS, Part # RVPLL13CBP. They are available at etrailer.com, Walmart and Amazon from $9.39, $14.60 and $8.99 respectively. I might add than my light is sealed around the periphery with clear Pro-Seal RV, and I haven't had any water intrusion in the light assembly. I don't see a whole lot of caulking around the light in your pic to compensate for the uneven surface of the aluminum diamond plate.
2016 Salem 27RKSS
11-15-2022, 08:05 PM
1000w light-bars are only a few dollars more
Tarpon Springs FL
2022 Salem 24RLXL
11-16-2022, 01:58 AM
I cleaned my lights switch on mine with CRC quick-dry electronic cleaner spray and it solved the issue without replacing.
Velosprout
2014 F150 SCrew 4x4 Max Tow Heavy Duty Payload 3.5 Ecoboost 6.5' bed Ingot Metallic Silver
2015 Rockwood Roo 21SS
11-16-2022, 02:07 AM
My docking light has also recently failed - some simple testing shows the switch as the component no longer in spec (take the cover off, then jump across the switch - your light should power on). I suspect that the fixture is not properly sealed against weather, and the fact that the unit is foward facing (into the weather as it’s being towed) is exacerbating the issue.
I was hoping to clean/replace the switch (it’s easy to access/isolate), but DW’s id of the part number (and a reliable source for replacement) provides a good alternative if cleaning with Velosprout’s CRC quick-dry electronic cleaner spray doesn’t work.
Just my.02, hope this helps.
2022 Rockwood Roo 235S
15kBTU AC; 12v fridge; 1kW roof-mounted solar panels; 80 amp MPPT charge controller; 3,500w pure sine wave inverter; 30a automatic transfer switch; MicroAir EasyStart, 600ah Chins LiFePo; Honda EU2200i (with Hutch Mountain propane conversion kit) gathering dust in the storage unit.
11-16-2022, 05:32 PM
Why can't you replace the switch?
https://www.amazon.com/Aokin-Rocker-...c-891e95133f20
11-16-2022, 06:07 PM
I agree with try cleaning the switch with contact cleaner. Also change the light bulb with a brighter led bulb, it makes a big difference.
XLR Thunderbolt 300X12HP
2014 Ram 3500 DRW
11-16-2022, 06:11 PM
Unless the switch is replaced with a weatherproof marine type it will continue to be a problem unless one never travels in the rain.
Sent from my SM-N950U1 using Forest River Forums mobile app
11-17-2022, 09:13 AM
11-17-2022, 09:38 AM
Definitely on my honey-do list. I never really used the docking light, but now that my switch has given up, it's bothering me.
Of course, I'm also interested in adding a LOT more LED floods all the way around, but that will likely never happen, so maybe I'll just follow 01tundra's footsteps...
11-28-2022, 07:14 PM
Originally Posted by doanshop
I just ordered this off Amazon, LED should fit, it did mine
BrandPartsam
Light Source TypeLED
Special Feature6" x 3.5" Oval led light provides bright light for illuminating the area outside your RV
Voltage12 Volts
PositionInside, Outside light
11-28-2022, 09:20 PM
I just changed my outside light on my RV with an LED what a difference
11-29-2022, 02:26 AM
You should think about changing it to a motion detection light.. You cam either use it as a regular light or a motion sensor. Great when you're out camping!
I did get the yellow lense, it was a little too bright with the clear lens.
MOTION-GUARD, MG1000-450B, RV Motion Sensor Light, 12 Volt, Exterior Mounted Motion Sensor Bright LED Porch Utility IP65 Flood Light with Battery Monitoring Sensor and EMI Suppression, USA Designed https://a.co/d/cC7hCu6
11-30-2022, 06:17 PM
Works when it wants to. I'm sure it's in the switch below. Sprayed some contact cleaner and worked the switch several times. Ok 2 yrs since. Borrowed time I guess. The switch is subject to road spray do to it's location and not a totally sealed rocker switch.
11-30-2022, 06:44 PM
I bought a bunch of 99 cent lights at harbor freight ..
magnet on the back and a hanging hook ..... about the size of a bar of soap
keep them in various places in back of truck , in the pass through, inside kitchen drawer ... and more.
great for hitching in the dark or changing a tire...
Tarpon Springs FL
2022 Salem 24RLXL
