I have a 2007 Throughbred and I am removing the audio system and will be installing a standard car audio deck. Can someone provide the wiring diagram so that I can match the wiring to the warness of the car deck?
You can take a 9V battery and tap the wire pairs to the terminals to locate each speaker and then connect to whichever output you want on the new head unit. Even if the current unit has a diagram, it's a crap shoot on the connections being correct from the factory any way.
There are but the are connected to an A/B/C switch. I think I should be good to go now. thanks to everyone for chiming in. I've installed probaby 25 head units in cars so i'm not sure why I was so squeemish on this install.
I started to get into the lack of the A/B/C switch an a typical car head unit- but it looks like you've got a separate switch. Most RV units have the switching capability built in.
I’ve got A B C speaker selection on my factory stereo in our RV. One does the living room, one does the bedroom, and the other does the outside entertainment for the outside tv and I have another outside tv area with two speakers.
