BAL Auto level and stabilizers, Strongarms, etc.
Got our new 3660 on Friday, and over the weekend getting it outfitted for trips. Once of the things I noticed is it wiggles up front. In back not really noticed, but it is up front. If you look at the 3660 it has a long front axle to pin distance, so it is natural to feel more wiggle up front. My last trailer used scissors jacks and I had JT Strongarms that I installed. They were GREAT, locked the trailer down where it felt anchored to a foundation. They were however not so easy to use due to the trailer being low to the ground. The 3660 is much higher so that will no longer be an issue, but not sure if they will work with the rear jacks.
Anyone who has installed stabs to the stabs on one of these, please chime in on what you installed. The fronts appear to be standard, replace the foot pin and use the kit hardware, but the rear, not sure how compatible they are with a universal kit. Also there are two other brands I'm aware of, but haven't really found the same use case yet.
