Old 08-31-2021, 05:44 PM   #1
battery cable relocation
I am replacing my useless LAB on my 2021 xlr micro bost with a new lifepo battery. the current battery is on the tongue. I want to put the new battery in the front storage compartment.
there is a battery shutoff installed in the compartment too. any ideas, examples or experience in re routing of the cables to the storage compartment?
need Ideas.
JimJimmy is offline   Reply With Quote
Old 09-01-2021, 02:19 PM   #2
Why do you want to put it in your storage compartment? My wife has to much stuff in that compartment for us to put a battery in there. Lol
Crutter is offline   Reply With Quote
Old 09-01-2021, 02:58 PM   #3
I put my batteries inside my trailer and just ran larger wires (to minimize voltage drop) to the original location and put a water proof box where the original battery box was to connect to the original house system.
I didn't want to pull the underbelly to rewire the main 12V system.
2021 Flagstaff 21DS
2015 Silverado 2500HD (overkill but convenient)
Renogy bits: 3000W Inverter/Charger, 400Ah LiFePo4, 40A DC-to-DC
Rich Solar bits: 400W of panels, 40A MPPT
Misc bits: LevelMatePro+, SolidRemote based wireless controlled LED storage lighting
jbflag21ds is offline   Reply With Quote
Old 09-01-2021, 03:00 PM   #4
LiFePo4 don't like the cold, so if you don't have the room for or want to deal with heater blankets, etc then moving them inside the trailer is the best option. Plus they are $$$$ so inside is better
2021 Flagstaff 21DS
Old 10-21-2021, 07:08 AM   #5
I know this is old but I wanted to see if this is a valid (workable) way to retrofit the 12v when relocating the Battery inside? I'm not real concerned about the wiring inside the unit but there are a lot of wires on the outside junction box that I don't understand. (brakes, lights etc)
sdp1234 is offline   Reply With Quote
Old 10-21-2021, 10:09 AM   #6
I just drilled a 1 1/4 hole in the pass through floor and ran the existing wires into the compartment. was easy, close all openings and your done.
Old 12-16-2021, 01:52 PM   #7
doanshop's Avatar
nice
You will love your lithium battery I know I did> I keep mine on the Tongue. Used heaters ssr and temp controller to warm batteries up for charging.
doanshop is offline   Reply With Quote
Old 12-16-2021, 02:01 PM   #8
doanshop's Avatar
nice
You know you could get a 8 d battery box to put it in if you wanted to
https://www.amazon.com/NOCO-HM484-Co...s%2C194&sr=8-3
Old 12-16-2021, 02:04 PM   #9
Its been working for me for a year now. Just use wire large enough to no get voltage drop when you run it from inside to the junction box in the original location.
2021 Flagstaff 21DS
battery, cable, cat, location
