Old 07-20-2017, 08:33 AM   #1
Buzzing Progressive EMS
Hi All,
I just installed a hardwired 50 amp Progressive EMS into my Georgetown. Whenever this bugger connects it makes a big click noise and then a continuous audible buzzing noise that I can even hear in the bedroom above it. Is this normal?
EricNJ is offline   Reply With Quote
Old 07-20-2017, 08:43 AM   #2
cbvp's Avatar
ems
Originally Posted by EricNJ View Post
Hi All,
No it's not normal.
Call PI Technical Support 9AM to 5PM EST 919-462-8280
C.B.
cbvp is offline   Reply With Quote
Old 07-20-2017, 09:01 AM   #3
I had the same problem with mine when I first installed it. I called tech support and they told me the contacts(?) needed to wear in and to plug/unplug it multiple times. Sure enough the buzzing went away after a short time. The click noise never goes away but only occurs once at first when you hook up to power.
Their tech support is great. Give them a call and they will tell you how to fix it or make it right.
2001 Ford F250 7.3l converted to F350 specs
2014 Flagstaff 8528RKWS
2006 model year Border Collie
Mtelkman is offline   Reply With Quote
Old 07-20-2017, 11:55 AM   #4
Failure is my business
2Evil4U's Avatar
After the thunk when it kicks on mine makes a bit of a 60hz hum. Only really noticable if you're in the room near the cabinet and nothing else in the trailer is running. I've never considered it an issue.
Current vehicle list: 17 RAM 3500 4x4 Cummins Aisin 4.10, 24 Cedar Creek 40CBK
2Evil4U is offline   Reply With Quote
Old 07-20-2017, 05:14 PM   #5
Just as confused as you
Scrapper's Avatar
I have worked with the types of contactors which are used in the hard-wired EMS for years. They are the same type used as motor starters for electric motors. One problem I have come across is that sometimes during assembly or shipping one of the contacts may get out of alignment and cause the buzzing.
As stated elsewhere, shutting off/ turning on the breaker at the pedestal several times can fix the problem.
If not, turn off the pedestal breaker, disconnect the power cord and open up the EMS cover. Inside you will see a arc cover with the label on it held on by 2 screws.
This covers the 2 (30amp) or 3 (50 amp) contacts. Remove the screws and look at the contacts. If any one of the contacts is not laying in there square (pic #3), that is the offending contact.
Using a small screwdriver you can get it turned so it makes a good connection when energized. Be sure the silver button is facing the correct way, you do not want it to look like the one in pic #4. If you get it the wrong way, you will have to push down on the square button in the middle of the holder so you can flip it over 180*.
Make sure that you don't lose or damage the small spring that holds the contact in position. Also, when putting the arc cover back on tighten the screws snug, do not over tighten.
Pics: 1) Arc cover, 2) normal contacts, 3) 1st contact not in correct position, 4) silver contact button facing wrong direction.
ID:	145478   Click image for larger version
ID:	145479   Click image for larger version
ID:	145480   Click image for larger version
Richard & Jill
Old 07-20-2017, 05:57 PM   #6
Great insight. The pics are a HUGE help.
Old 07-25-2017, 08:17 PM   #7
Installed same unit in my 2306 a couple months back. I actually recorded the noise. And it was noisy.....then after a short time the buzzing went away. Im happy with the unit now, works great with the charging wizard remote.
2018 Toyota Tundra Crewmax
2017 Mini Lite 2509S
2012 Mini Lite 2306, 2000 Storm 32ft Class A w/dbl slides, 1998 Class C 23ft Fleetwood, 1990 8ft Lance.
Nights Camped 2016- 15, 2017- 30,2018-27, 2019-36 2020-21
ace911 is offline   Reply With Quote
Old 07-26-2017, 09:54 PM   #8
What is charging wizard remote?
Old 07-26-2017, 10:44 PM   #9
charge wizard remote is a completely different topic. best to start a new thread about it. fyi, it is a remote fob that is part of the progressive dynamics converters. go to their website for an explanation
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
CHICKDOE is offline   Reply With Quote
Old 07-26-2017, 11:06 PM   #10
HONDAMAN174's Avatar
I have read on here that progressive recommends not to mount against a flat surface. Others have put a few washers between the casing and wall as spacers and the hum doesn't resonate thru the wall. Especially with 50a unit.
Just glad to get away
Old 07-27-2017, 10:14 AM   #11
Scrapper's Avatar
I didn't see that in my instruction booklet. Mine is screwed down on the floor. I can understand how you may get vibration if you mount it to the thin wall and haven't a firm backer behind it. As thin as the walls are it wouldn't take much bouncing around on the roads to have the screws work loose.
Richard & Jill
