Similar process in our Rockwood Mini-Lite. We pulled the top bunk out for the same reason.
Remove the mattress, then take off the plywood from the top and bottom of the base. In our case, the top is screwed on, the bottom was glued so it had to be pried off.
You can then see the aluminum frame and the screws around the perimeter that hold it in place. To lessen the chance of scraping the walls, I cut the frame into sections with an oscillating tool, and removed it in several pieces.
A very straightforward job, but it will be almost impossible to save for re-sale...
Rockwood Mini-Lite 2509S
Toyota Tundra 4WD
