I've done a bit of research and mounting the bullet inside is not the best idea because at WiFi frequency, the signal from the antenna would be attenuated. Same for connecting the antenna to a router.
Better to run cat 6 to the bullet which is what I plan to do. No signal loss.
Though you need to determine where the WiFi signal is coming from and point the antenna, a directional antenna is capable of connecting over a much longer distance than an omni directional one. Miles even.
The bullet has a router built in, but I'm using a second one for inside the camper mainly because I already have one. Another option would be a wireless access point.
-- My wife complains I never listen to her. Or something like that.
2017 Heritage Glen 368RLHBK Limited
2017 Ram 3500 4x4 Crew, 6.7 Cummins
