Old 02-16-2024, 10:44 AM   #1
Changing shower to glass door
Hello
First time poster. I grabbed a Flagstaff Micro 21 ft trailer. Question does anyone have any links to parts to grab. For example, it currently has a corner shower with a curtain instead of door to keep water in. I want to change/update that to a sliding door or open door type of shower. Or other ideas are welcome as well.
Floor plan - https://www.rvusa.com/rv-guide/2015-...21fbrs-tr22691
mcj212 is offline   Reply With Quote
Old 02-16-2024, 11:46 AM   #2
Kanadian Kamper
kenandterry's Avatar
Some factory corner showers are round, however, according to your picture, yours appears to be 3 sided curved. You need to accurately measure all your sides in order to know what shower enclosure will fit properly.
Not all RVs are like yours…..not all showers are like yours.
Ken and Terry
2018 Sunseeker 2430S-CD, nicely modified and carried by a 2017 Ford E450 Sport with 6 speed Triton V-10
kenandterry is offline   Reply With Quote
Old 02-16-2024, 02:42 PM   #3
Thanks Ken/Terry.
I understand that. Just hoping some more experienced people would have a site that I can order from. Or maybe can I use the ones from Lowes or Home Depot as long as they fit?
Old 02-16-2024, 02:52 PM   #4
Kanadian Kamper
Just goes to show you how we all want something different…..
In both our motorhome units, which had/have 24”x32” rectangular showers, I changed out the factory shower glass doors to Extend-a-shower curtain units, to give way much upper body room.
https://www.facebook.com/strombergca...5500493309684/
Ken and Terry
Old 02-16-2024, 03:06 PM   #5
Measure and buy
Originally Posted by mcj212 View Post
Hello
Measure the dimensions of your current base. Then put this into Google:
rv shower enclosures
and find one that fits your base and your desires.
Ideally, the drain will be in the same spot, or you might be able to adjust the slip fittings on the trap. Worst case, you might have to do a little plumbing.
They aren't pre-drilled for shower valves and head, so you can carefully drill the new one to match the old one.
Larry
Larry-NC is offline   Reply With Quote
Old 02-16-2024, 09:16 PM   #6
coney's Avatar
Hello
you might have to replace your shower pan and re-plumb
Central Florida
2017 Nissan Pathfinder SL
2019 Shamrock 19
coney is offline   Reply With Quote
door, show, shower
