DW has the correct answer.
120VAC fixtures, as long as they don't already contain the lamp itself nor any electronics for dimming/switching, can be used in 12VDC applications w/o issue.
What's needed is 12VDC lamps to fit the socket in the fixture. In the case of the ES (Edison Screwbase) type lamps typically used in 120VAC applications, DW provided a link to LED lamps powered by 12VDC.
Before purchasing any 120VAC fixture with a socket other than the ES type, verify you can find 12VDC lamps for those fixtures. If so, have fun exploring!
2016 Sunseeker 2250LE/Chevy
Formerly: 2000 Four Winds 26Q/Ford, '96 Kit Sportsmaster 22' 5th wheel, '91 Sunlite truck camper, Wildernest flip-top canopy
