Did this on a previous trailer. We wanted the sleeping areas darker and not to have to pull blinds every time someone needed to change clothes.
It came out quite good and my Wife was pleased with the results. When you purchase the film also buy the application kit. Before starting check out the many U-tube video how-to's. Start on the smallest window first. Keep the film/glass wet. Most importantly, take your time.
I did a small window first, got used to applying and trimming the film. I was not pleased with my first try so I removed the film and started over with a new piece. The second time around things went well. The more windows I did, the easier it got. It takes 3-5 days for the tinted to dry to the window and look crystal clear
Follow the instructions, take your time and you should be happy with the results.
