To adjust the temperature in a Dometic RM2652, you are to move the plastic slide up to make the fridge colder.
The plastic slide that holds the thermistor in mine was loose. Loose enough that when I slide it up the fin, the thermistor slide down the sleeve. Moving the slide did nothing to move the thermistor.
First I drilled a small hole in the slide. Then I used a tie-wrap to clamp the thermistor in the slide.
Now when I moved the slide up the fridge got down to 34F.
Later it got down to 30F and I moved it down a 1/4 inch. I still plan on a 12v fan to circulate the air inside the fridge.
