Old 06-26-2020, 08:48 AM   #1
E-Pro access to audio system and wiring
We just purchased a 2020 E-Pro Flagstaff 20BHS, with the Furrion DV7200 installed. The Aux input port is blocked for some reason, the radio reception is terrible, and when connected to my phone via Bluetooth, there is a lot of crackling. I have read a few of the threads about other complaints and solutions, like upgrading the speakers. I would like to connect my XM radio before considering replacing the unit. Anyone know how to access the cabinet where the unit is installed? I expect the panel with the toggle switch comes out, but there's probably a trick to it, and of course I would prefer not to do any permanent damage in the process.
daberg is offline   Reply With Quote
Old 07-15-2020, 10:35 AM   #2
What do you mean by "the port is blocked", physically or electronically? You should be able to pop the Furrion out of the cabinet and be able to access all wiring behind it. In my camper there's a huge open cavity behind the electronics.
Luke V is offline   Reply With Quote
Old 07-23-2020, 06:46 PM   #3
the square plastic ring around the radio unit pops off, and there's 4 screws under it holding the radio in place.
-Jamie
2020 GeoPro 19FBS
2021 Ram 1500
Dupesy is offline   Reply With Quote
Old 09-28-2020, 11:44 PM   #4
jbcrick's Avatar
Originally Posted by daberg View Post
... The Aux input port is blocked for some reason....
The port is plugged with a plastic pin that was only used to hold the information brochure/tag. You should be able to simply pull it out to unblock the port.
Nikki, My Black Lab and Travel Buddy
2020 Rockwood Geo Pro G19QB
2016 Nissan Frontier SV 4WD
AF&AM, Lodge #584 of North Carolina
jbcrick is offline   Reply With Quote
wiring
