Old 08-04-2020, 06:26 PM   #1
NXR
NXR's Avatar
F53 - Added driver's side power outlet and USB ports
On the driver's side of the dash there is a small rectangular wood-grained panel that was just itching to have something mounted to it so I did.
There's nothing behind that panel to get snagged in a drill or anything. These are what I installed:
Power outlet: https://www.qsradio.com/shop-now.htm...egory=11543079 - $12
Dual 2.1 amp USB outlets: https://www.qsradio.com/shop-now.htm...egory=11543079 - $12
Double mounting panel: https://www.qsradio.com/shop-now.htm...egory=11543079 - $5
What they have available: https://www.qsradio.com/shop-now.htm...=0&sort=normal
I used a 1 1/8" wood bit (paddle bit) for the two big holes and a pin vise to drill the four mounting holes for the plate. I used the included self-tapping screws because the sockets themselves have a big nut on the back to hold them in place.
When drilling the two large holes there are two layers of plastic, the thin trim panel and a thicker plastic panel behind it.
I used 1/4" wire loom to run the wire from the driver's side to the passenger side where there is another set of power and USB outlets. It's pretty tight going from one side to the other so I followed one of the heating/AC ducts. I used a piece of home Romex as the guide wire because it's stiff but flexible.
I actually ran one set of power wires over and jumped the two added sockets together. I tapped into the same power wire for the passenger power outlet because it has a 7.5 amp inline fuse. I added my own 7.5 amp fuse for the new power outlets just ahead of that fuse because we don't have anything that pulls a lot of power anyway.
Yes, being a contortionist does help.
HTH,
Ray
Name:	Driver Power Outlets.PNG
2020 Georgetown GT5 34H5
NXR is offline   Reply With Quote
Old 08-04-2020, 06:43 PM   #2
Mooney 78865's Avatar
HTH,
Ray
I like it! I was actually thinking of mounting a TPS device there, but after seeing yours I think I may just do something like that. It really does lend it's self to wanting something there.
2014 Georgetown 378 XL
2016 Moto Guzzi Stelvio
2016 Lincoln MKZ "Toad"
Mooney 78865 is offline   Reply With Quote
Old 08-04-2020, 07:28 PM   #3
Tax_Man's Avatar
Did that a couple of years ago. Got mine on Amazon. The lighter socket is used for the GPS and USB for other stuff.
2007 Georgetown 350DS
2007 Jeep Liberty
Wife, Me, and the dog
Have Fun!!!
Tax_Man is offline   Reply With Quote
Old 08-04-2020, 07:40 PM   #4
Dodge Guy's Avatar
My 2012 has a regular 12V outlet there. I use it for my IPad charger.
2012 Georgetown XL 350TS, Hellwig front/rear sway bars, Sumo Springs, Blue OX True Center steering damper
2013 Ford Explorer LTD toad, Roadmaster Stowmaster 5000, VIP><Tow Brake
Better to have a bad day of camping than a good day at work!
Dodge Guy is offline   Reply With Quote
Old 08-04-2020, 08:09 PM   #5
NXR
NXR's Avatar
There are two dual USB outlets in the center stack on the later models as well as two power outlets. Then there is a dual USB outlet and power outlet on the passenger dash-mounted "workstation" and a 120 VAC outlet by the passenger's right knee. There also are two USB outlets on the driver's side but way up high for use by someone in the bunk bed.
But nothing on the driver's side accessible to the driver so I added them.
Ray
Old 08-04-2020, 10:18 PM   #6
Dodge Guy's Avatar
I fixed the lack of then on mine also!
I added a dual USB with digital voltmeter to my new console As well as another 12V outlet along with a USB that connects to the radio for apple car play!. I also replaced the passenger side 12V outlet with a dual USB outlet. And I still have the 12V on the drivers side with a plug in dual USB outlet! Much more user friendly and up to date!
ID:	235747   Click image for larger version
Old 08-06-2020, 09:24 PM   #7
NXR
NXR's Avatar
I saw a video today that made me go "Why, that's a great idea!"
I don't know what motorhome he had, but he had two 12 VDC power outlets on the front side of the center stack. So at the very top on the vertical edge facing the windshield where they were out of sight. He had his "stuff" plugged in there so he had no cords draped down the center stack.
That seems like a no brainer, now that I've seen it.
That should be fairly easy to do on a Georgetown because the center stack has that "hump" at the top. I'm just not sure I want to remove that panel and pull it back because it has everything mounted to it. Ugh.
Ray
Old 08-07-2020, 09:47 PM   #8
Ray
It's not that bad, at least on my 2014 378. I've had the front section off a few times for various exploration trips!
Old 08-08-2020, 07:31 AM   #9
NXR
NXR's Avatar
Good to hear. If I decide to add them, I figure I'll just pull the panel back a bit to get a look to assure there are no wires, drill the holes and mount the power outlets with the wires pre-attached to minimize disturbing the existing wiring.
Ray
power
