fixes/mods
Top of the afternoon to all, Ive had a busy day today,
I fixed my entry door, the enrty door ball end, for the door strut broken off at the door sill, while at Ocean Lakes, dirlled a 5/16 hole through the door frame and replaced the socket end w/ a clevis. One of my front hub caps was loose, found that part of the fingers had broke loose, drilled every 5th finger around the hub cap w/ a 1/8 drill and used pop rivets to reattached the finger ring. I installed a Hellwig front sway bar, changed out the stock head lamps, and the last thing a propane extend a stay valve. Changed the engine oil and filter. Depends on how tomorrow starts off, I got a few more things to add
My off to Dinner
